MV Sport S3 8P Downpipe Conversion
david_phillips95 Nov 23, 2009
  1. david_phillips95
    david_phillips95 Member VCDS Map User
    504
    Came across this downpipe, anyone seen this before? its a conversion that is a straight swap with your standard downpipe. This means you can rid yourself of the highly restrictive oem downpipe yet keep the oem look. Comes in at £499 which IMO aint bad. I emailed MV sport for more info:
    Thank you for your enquiry regarding a downpipe for your S3 TFSi.
    I can confirm that we do supply a 70mm downpipe and 100 CPSi sports cat to fit your car that you can use with the standard system. The design and components used give a considerable increase in flow and efficiency over the standard unit. When used with our tuned system we have seen gains of up to 28hp, but I don't currently have any figures for the standard system.
    This is a stock item for us and the price is £499 including vat.
    Here's some pics:
  2. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    From what I've seen the MV Sport stuff seems to be good quality, and good to see some more companies making these. They won't let on who are making these parts for them, but they are definitely a lot better than much of the competition from what I've seen.
  3. dc240969
    dc240969 Member VCDS Map User
    925
    Not really seen pics of the downpipe etc before but that is not nice, that restriction, and why it splits into two is silly. lve heard that that part is or should get a recall.
  4. david_phillips95
    504
    the standard downpipe is really poor for performance but im sure it has its reasons for being designed like it is. i very much doubt there is a recall for the downpipe.
  5. Spin140
    Spin140 Well-Known Member
    2,196
    186
    Be good to see a picture of the Milltek item alongside the other 2, useful post thanks
  6. david_phillips95
    504
    the milltek dp is 3" bore and the mv sport dp is 2.75", the milltek will not mate up with your standard system without a custom made joining section thoough. After viewing the milltek catback vs the oem catback exhaust it made me realise the oem catback exhaust is pretty well designed, if you look at the picture below you will see the oem boxes are slightly larger and will be slightly more restrictive but the pipe diameters are similar to the milltek:
    I really like the tips on the standard exhaust and IMO i think there hard to beat, Before i came across this DP i would have ended up going with a TB system e.g milltek/blueflame but the only thing i never liked about these were the tips being larger and round unlike the smaller and oval oem tips. Looks like i will be going with the MV Sports Downpipe :)
  7. DaveS3Turbo
    DaveS3Turbo Sepang Blue S3
    1,065
    Nice, good info. What tail pipes have you gone for on the milltek? Special 80mm?
    Any more picturs of the tailpipes?
    David
  8. david_phillips95
    504
    Sorry i think you have misread mate, i was just using that picture of the milltek to compare it to the standard system. I think those are the special 80mm tips tho.
  9. dc240969
    925
    No, maybe not a recall but close enough. Whenever there is a problem with these they quickly ask for it back and give a replacement no qs asked.
  10. timott
    timott New Member
    Hi mate isn’t this stuff manufactured by Scorpion exhausts? :confused:
  11. V6Pete
    1,491
    They say apparently not... who knows though!?
  12. timott
    timott New Member
    Weird, was chatting to someone at show or online can't remember they said they were just Scorpion or something, like you said mate - who knows!
  13. V6Pete
    1,491
    The guy behind MV Sport is the guy who used to own Motech before it went pop, who were the main Scorpion distributors at the time.
    Not sure if this means Scorpion make the MV Sport stuff - they say not, if this just confused people?
  14. Jamiekip
    Jamiekip Member
    717
    I have the Miltek DP and Cat on my car mated to the OEM back box.
    Have done so for about 10 months. No problems and delivers a significant increase in performance, especially in the mid range.
    As mentioned the OEM back section is pretty free breathing.
    If you're going to do this why not go the 3" route and get the best flow?
    Don't be fooled thinking it's a nightnmare to mate with the OEM section, all exhaust fitters have 'shims' that alloow different diamteters of pipe to mate.
  15. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    So what difference would a DP swap make if you have REVO stage1 and no other bolt ons?
    cheers
    Paul
  16. david_phillips95
    504
    i think you would need to go stage two for it to make full use of the DP, although stage two is usually for cars with exhaust and an intake i would imagine you could get away with running a performance panel filter. At £50 to upgrade to stage two it would be worthwhile
  17. david_phillips95
    504
    I thought about it but i would prefer to buy a DP that i can take out the box and fit instead of buying one and modding to make it fit. Also the MV sport is 2.75" vs 3" milltek so there is not as big a change going from the DP to cat back, i never fancied going from 3" to a standard cat back as i would imagine it would cause a pressure build up leading to extra stress and heat. Im guessing MV Sport have taken all the factors of the standard cat back into consideration and designed a DP to suit where as the milltek is designed for a 2.75" performance cat back.
  18. phil76
    phil76 Active Member
    572
    40
    I cant see that been much of a problem though to be honest because even Oem exhausts have larger pipes meeting smaller pipes as shown where the restrictive flow issues are so you would think then there would be issues with pressure and heat build up.
    Have you got a link for there site by the way just wondering if they do anything for the porpers 2.tfsi quattro unlike all these millionaires with S3's:blush:
  19. AuldReekie
    AuldReekie Member
    770
    Phil, just a quickie mate. I have looked on their site (MV) but cannot see any specifics to VAG exhausts, but I know that one of the site sponsors on here put up a thread about them recently. Sorry can't remember who it was off the top of my head, but I will have a sniff about later for it.
    Edit: VAGTECH were the ones "A3 2.0 TFSI coming soon"
  20. ryanstewart9
    ryanstewart9 Member
    494
  21. BOSSS3
    BOSSS3 Member
    119
    They are the 80mm slash cut tips.
  22. phil76
    572
    40
    Yeah that would be sound mate if you get chance :salute:
  23. david_phillips95
    504
    Give them an email, they were quick to respond to my enquiry. If we could get enough interest we could ask if they would do us a discount for a group buy. I know of others who may be interested. Who do i need to get in touch with here to get permission for a group buy thread?
    Cheers Davie
  24. phil76
    572
    40
    Staz i should imagine or he should be able to point you in the right direction,and yeah have e-mailed them waiting for reply,cheers folks
  25. david_phillips95
    504
    Emailed MV Sport today about discounted prices if anyone is interested:
    Hi Davie
    Thank you for your email and your interest in our products.
    I can confirm that we would be more than pleased to offer your members a 10% discount on our products. This brings the price of the S3 downpipe down to a very attractive £449 including vat.
    Furthermore if you could get 2 or 3 members to purchase at the same time, we will stretch that to 15% or 424.00 including vat.
    I would also confirm that this is a stock item for us.
    If you have any more queries please just ask.
    Best Regards
    Mike
    MV Sport Sales Team
    Tel: 0845 505 5011
    Fax: 0845 505 5012
    www.mvsport-tuning.com
  26. akash_sky1
    akash_sky1 Active Member
    1,181
    Will this fit the 2.0TFSI as well? I might be interested in one
  27. david_phillips95
    504
    The S3 one wont fit, they are releasing a DP for the 2.0tfsi, if you enquire through their website you may be able to get a date for its release.
    Davie
  28. david_phillips95
    504
  29. david_phillips95
    504
    MV Sport have downpipes to suit the A3 2.0TFSI & S3 2.0TFSI see group buy for more info.
    Cheers Davie
  30. baldwined30
    baldwined30 New Member
    21
    Not sure if any of you guys are interested but ive just had this full system fitted to my edition 30! It is a very nice and well made piece of kit although personally I find a little too loud!
  31. akash_sky1
    1,181
    By full system do you mean MV sport downpipe & TBE?
    Too loud?! lets see a vid...
    mines waiting in the parcel depot :_(
  32. akash_sky1
    1,181
    i already have votex back box so mines louder then standard anyway..mostly outside. only concerned with the performance though
  33. baldwined30
    21
    ill try and put a vid on tomorrow! I was only interested in performance too not interested in loud noise!! The thing is quick now! Especially with DSG!
  34. akash_sky1
    1,181
    what power do you think the 200ps engine with generic stage 1 map , MV DP & racecat plus votex rear would be pushing out? I would have guessed 260-270 brake?
    MTM claim 272ps from their stage 2 tune which involves remap & full TBE ( including a rather weedy looking DP which still has the two narrow forks in it)
  35. akash_sky1
    1,181
    Ps Also currently I have the standard diverter valve which is commonly known to be pretty lame. Do you think the lower EGTs which would result from the much large DP/racecat will improve its life expectancy, as the turbo will run slightly cooler?
  36. baldwined30
    21
    Not sure on any of your question to be honest mate, never looked at the KO3 set up! Sounds about right, power wise. Just as a reference, on the way back from MV sports, saw of a BMW 335i, he was sat right up my behind, see you later!
    Must also add, the guys at MV were second to none, thought i had a problem, turned out i didnt. They bent over backwards to help me!! A1! would use them again in a heart beat!
  37. akash_sky1
    1,181
    took mine to the garage today, but he realised its gnna take longer then expected to fit so cudnt do it today :-( also no gaskets have been provided to join the different sections which is surprising, gonna have to try call them and see whats goin on
  38. Boydie
    Boydie Boycie VCDS Map User
    3,293
    397
    I saw MV sport and their S3 at Edition 38 last year - looked like good gear!
  39. baldwined30
    21
    Gasket????? it fits on to the turbo!! Make sure you look all through the packaging, i threw a piece away! luckily my previously life i was a hobo and found it in the bin!!!
  40. akash_sky1
    1,181
    Yeah had it fitted today, not got a chance to properly test it thru the gears though. Strangely at idle its quieter!! When there's any load on the engine at all though you can easily tell the centre silencers missing and can hear a nice reedy/bassy sound from it.
    Although limited drive so far you can deffo feel a bit more in the mid range.
