Muti Function Steering Wiring Broken! and Airbag Fault .. Help!!
sekenzo Jul 1, 2013
  1. sekenzo
    sekenzo Member
    102
    Hi,
    I have a 3 spoke multiple function steering wheel. Was doing a DIY DIS/Cruise control mod today and accidentally snapped the wire on the steering (the connector and wire is now separate). Is there anyway i can get a replacement part or do i need to purchase the whole steering wheel? Also is this the cause of my airbag fault code (below)? Thanks!!
    2 Faults Found:
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 1048575 km
    Time Indication: 0
    01587 - Igniter 2 for Airbag; Drivers Side (N250)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 1048575 km
    Time Indication: 0
  2. NHN
    29,298
    1,701
    Show us a pic of the damage before advisory on what to do next.
  3. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    As Nigel has said, show us some pics.
    But I don't see how you "accidentally" broke the wiring
    I have a spare wheel with buttons and wiring intact if interested? Going cheap, just want it out the way.
  4. sekenzo
    sekenzo Member
    102
    Sorry for the delay. Here is the pic.. I have sorted the Airbag faults. Turns out to be the loose yellow connector.
    I suspect the wire must have caught between the bolt and the airbag when tightening.. the problem is all three wires inside the 'bundle' are not labelled and are all the same color - black!
  5. sekenzo
    sekenzo Member
    102
    How much are you willing to sell the wheel? Is it an sline wheel?
  6. NHN
    29,298
    1,701
    Just repair the wires.
  7. sekenzo
    sekenzo Member
    102
    The problem is all three wires look the same so it will have to be a trial and error exercise. However, I am very scared to test it with the airbag not fully secured and battery connected... Any advice will be welcome!
  8. NHN
    29,298
    1,701
    You could always send it to me for repair.
