Music failed to load
A3sportbackMark Oct 23, 2013
  1. A3sportbackMark
    A3sportbackMark Active Member
    711
    230
    43
    Switching on the music in the car this morning, the MMI displayed the message
    Loading Source
    Please wait...
    and I waited, the music never came.
    I was attempting to play music from the SD card, changed the source to the AMI using a USB memory stick and then to the phone through Bluetooth.
    Still I waited.
    The radio, phone through BT and sat nav worked perfectly well.
    Removed and replaced the SD card and USB stick, switched off engine and restarted, still no joy.
    I left the car for 8 hours whilst at work, and when I returned everying was ok! :think:
    Anyone else seen this?
  2. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    952
    394
    Not specifically that but it did corrupt an SD card for me, and if I hadn't noticed then may have developed into the issue you are having.
    Luckily I had a backup with all the folders & artwork so the card in there now has the write protect tab on. I don't know whether the system obeys that though; I know the early TomToms didn't.
    John.
  3. 97catalunya
    97catalunya Active Member
    546
    162
    43
    I haven't seen this but my sat nav froze while going round a roundabout joining the motorway on a trip back from Birmingham at the weekend. Tried turning it off (holding down the volume button) swapping sources etc but nothing!
    Fortunately my fiancé was with me and the book was in the glovebox, so while doing 70mph down the motorway I got her to look up the resetting procedure for the MMI and cured it. I'm just glad I wasn't on my own as I hadn't memorised what buttons to press thinking I wouldn't need to know?
    I think because of the amount of time you had left the car the MMI had fully shut down and then rebooted when you got back in it.
  4. paullowther
    paullowther Well-Known Member
    739
    445
    Regarding the SD card, has anybody had any experiences of performance improvements by using a higher read speed rated card?
    I see quite drastic differences in price according to the read/write speed of the cards (same make and capacity)
  5. GrumpyEngineer
    GrumpyEngineer Active Member
    101
    33
    High read and write speeds will only make a difference when initially copying the music onto the card from your computer.
    The max bit rate of a mp3 is 320kb/s so as long as the card is faster than that (give or take) then it will be fine. A 'class 4' SD card, which is about the slowest you'll find these days is 4mb/s or 12.5 times faster than the highest data rate mp3 so it is more than fast enough. Now whether a faster card will appear more responsive when navigating through the tracks on the card is another matter.
    Just because you have a faster card it doesn't mean the mmi will be able to take advantage of the extra speed and do anything helpful with it.
    Rich
  6. 97catalunya
    546
    162
    43
    I think the read/write speed (class) of the card is more relevant to cameras and DV recorders, I'm not sure it will make too much difference to music?
  7. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    Buy the highest class/ fastest card u can.
    Plenty fakes out there rebranded also.
    Yes it might not make too much difference but really with storage u get what u pay for :)
  8. paullowther
    739
    445
    That's what I was trying to get at, navigating around I figured might be slightly quicker. Last year I switched to SSD's on my laptop and the speed at which files are accessed is noticeably quicker than before. Programs open in the blink of an eye etc... That's all down to the higher read/write speeds. I just didn't know whether the hardware running MMI would be the limiting factor. Does anybody know where I can find the specifications of the MMI system? Processors, memory etc...
  9. A3sportbackMark
    711
    230
    43
    Well, it's happened again!
    As before I was incrementing (or decrementing) the track number being played using the small volume dial on the central console.
    Same symptoms as before, this time I tried a factory reset on the media option, still no good. Was loathe to do an MMI reset for fear of loosing all my settings........or do you loose your settings?
    Solved the problem by leaving the car, locking/unlocking, then music loaded. This is a bit impractical on the motorway!!!
    I wonder if there is a software upgrade to fix this little issue.
  10. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,690
    528
    Could it be a corrupt mp3 file crashing the system?
  11. A3sportbackMark
    711
    230
    43
    Good point, didn't think of that.
    I'll keep an eye out if it's a particular track if it happens again, both times from the SD card.
