MUSH Developments` S3
MUSH Mar 15, 2011
  1. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Another small update, busy again so nothing massive but ive now got the jetex filter i ordered. Offered it up to see how itll fit. Ill jump on making a heatshield eventually but for now at least it fits/looks good
    Also fitted the new EGT sensor, the connector for this is at the rear of the bay behind the catch tank, thats where i wired it to when i made the loom, no point in having it at the front of the bay. All Plumbed in...
    And got a few more pipes painted along with the inlet. Ill fit this manifold to get it running as i havnt had the time to even think about the RMR one i have.
    Next task is a good one, ill be fitting the pipes/manifold and the final fit of the front panel which means coolant can be filled up and were nearly at the startup!!
  2. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
  3. MUSH
    713
    12
    Cheers mate, Not too long really. Sick of making excuses but its not my priority at the minute. Im busy living in a building site so thats the biggest priority. However ive made some good progress so it should start to get interesting...
    Started by fitting up the charge pipe that i sprayed up...
    Really impressed by how this pipe turned out as its 4 angled pipes welded up and it fits perfect!
    And then fitted up the inlet manifold. As befroe this is purely temporary as ill get the RMR made up soon.
    Got all the vacuum feeds connected up, theres only two, one which feeds the DV directly, and then one which feeds the FPR which is also T-d off for the boost gauge also...
    You may notice my dipstick tube comes up in the wrong location, however this was the position it came form the machine shop. Ive measured it and its spot on, but its straight up which puts the dipstick location slightly off. Doesnt bother me as itll sit ok in the runners of the new manifold.
    Anyhoo, as that was all fitted i chucked the front slam panel on for the final fitment.Felt good to do this eventually. 5 mins of fitting coolant lines meant i could fill it up!! 50/50 mix
    Itll still need bled and circulated but theres no leaks..........for now. lol
    So the bay is looking good....
    And for the few people that have been asking about my fmic, heres a few pics. Im confident itll work well, but in the fututre if the AH coolers prove to be good i may well invest in one of them. We`ll see. It all depends how this works out to be fair. Cant complain, hasnt cost me a great deal so far and it fits champion.
    Anyways, heres a few...
    Drivers side fitted up. Ive left the silicone slightly longer here incase i do change in the future.
    The aircon pipe you can see here is actually knakered but ill be getting that repaired very soon.
    Passenger side...
    Decided to then ultrasonically clean my injectors, what a great piece of kit this is. Did it twice just to be sure, the first time there was loads of **** left in the bowl afterwards...
    And then fitted up....
    Just got my standard S3 injectors in for now. With the idea that the ECU will run in closed loop wideband lambda and trim off any excess fuel. If the trims are excessive ill do it with unisettings.
    And fuel rail fitted...
    Heres a quick pic to show the turbo coolant line which then connects to the after run water pump...
    I then worked on getting the passenger side connected up, took loads of trimming of the silicone to get it right buts its there now...
    So the bay is complete, and looking good. Ready to power it up now!
    Still not totally happy with the room on the rhs of the bay, the battery box takes up loads of room. I may downsize this or relocate it to the boot which would free it up lovely. We`ll see about that.
    I gave my battery to my pal for his mk4 when his died in the winter so as soon as i get a new one some time this week, ill be powering it, fuelling it up and checking for faults before priming the system and firing it up!!
    Cant wait...!!
    Thought welcome.... ;)
  4. Westy
    Westy Well-Known Member
    17,443
    1,105
    Great progress. I'm looking forward to the videos of it's first breaths.
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Great .... im more scared than you........:beerchug:
  6. MUSH
    713
    12
    You and me too brother!
    I am rather nervous Dave, in my many builds ive never had so much on the line as now!
  7. Andy123
    Andy123 Member
    260
    Good luck Mush, hope it fires up ok for you! I forgot to earth the gearbox on my very first attempt and it did nothing- I then thought oh sh*t but then put 2 and 2 together and realized the starter wasn't even turning and that I had forgotten to earth the box!
    I noticed your coolant is up to the level just underneath the drips-is that the indicator for the max level on the reservoir?
  8. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    ooo exciting top work again mate. cant wait to see it go
  9. MUSH
    713
    12
    Cheers Andy. At least it was a simple mistake! Ive defo got the earths sorted, a bad earth on my 8v mk2 killed the ecu which flooded the engine and wrecked the big ends! So i think i learnt my lesson, lol. Ill be connecting up vagcom to ensure the rest of my wiring is also correct. Sure therell be a niggle somewhere, but there always is after builds like this.
    The correct coolant level is slightly lower, this is just where mine is sitting at the minute. As soon as i turn it over a bit and get the pump working ill have to top it up so im expecting that already.
    Fingers crossed though eh?
  10. MUSH
    713
    12
    Cheers mate, ive got aspirations of rocket like movement, lets hope im not dissapointed ;)
  11. MUSH
    713
    12
  12. DaveA3
    2,370
    15
    im sure we can arrange someone to do a countdown! lol
  13. Smokey_clark
    Smokey_clark 12th Gear
    210
    Sweet, good luck on the first start mate can't wait to see it!!
  14. MUSH
    713
    12
    Cheers, its today im going to play with it so...
  15. MUSH
    713
    12
    So, got 5 mins spare today so i jumped on getting the car started up. Been dying to do this for ages and this is just as important as the mapping session so had a bit of nerves...lol
    Now, i have a severe lack of battery as i was good enough to give me pal mine but he hasnt since reciprocated the love, so im still waiting for that as yet. So i got me work car parked up out side the garage, disconnected the battery and connected that battery up to the S3 via my jumpleads.
    Before i started it up i needed to do a few little jobs. First i replaced the 1BAR wastegate spring(Large Blue) with a 0.7BAR (Large Yellow) spring. This is to help later on, but i wanted to get it in now so i dont have to unnecessarily take it to bits again.
    And then i got the EH&S up to scratch...
    So i could then connect up the battery. Nice to see all the lights on the inside again, its been a while.
    I chucked in £10 of petrol as i had previously drained the full tank it came with for my lasses car. And then before starting it up i removed the J271 ECU relay and span it up for a good minute to get the oil going round the system. Checked that oil pressure was good and as i left the turbo oil feed slightly loose i could see oil getting through the union...
    So i tightened that up and chucked the Relay back in ready to start up. I turned it over but it wouldnt fire. Had me some head scratching as everything looked ok on vagcom, no faults so had to check a few things over and found that the coils werent firing. My heart sank for a minute, right up until i discovered id been a tit and hadnt connected up the wotbox controller. Due to the nature of the controller it opens up the power line to the coils and without the controller connected it obviously didnt feed power to the coils. monumental DOH...!! lol
    Anyhoo, got it connected up and went for it again. Fired on the start of the key WOOHOO!!
    Fired up and idled up nice and easy, sounded a little tappy to start with as expected but after about 30 secs it sat mint with no horrible noises!!! Had the DIS going a bit doolally as the coolant wasnt totally up to the line so i had to top that up but it all went well. I videoed the first start but the video is about 2 mins long so i might upload that a bit later.
    Had it running for a good few mins, got the temperature up to 90. Took another shorter vid that looks poo after compressing....
    Although after a few minutes i started getting vapour rising from around the back of the engine. Some of this was to be expected form various painted bits curing but it got a bit worse, traced it to the RHS matrix connection, it was leaking coolant, not that you can see from this photo...
    There was a steady stream of coolant coming out of it so i stopped there to let it all cool down. Ill look into that when i next go in the garage.
    But there were no other niggles that i could see. Im sure they will surface if they are there though so lots more fun to be had!! Good thing is theres no signs of bad smoke coming from the exhaust, and the exhaust sounds ACE! So for now, i am a happy bunny....
  16. AGU-TURBO
    616
    Congrats mate. Well happy for you. Sounded a little tappy on the vid but that should clear when the lifters have filled up, Exhaust sounds ace.
  17. s3dave
    10,110
    736
    Great work.....cant wait to see this in action....
  18. MUSH
    713
    12
    Cheers chaps, just need to look at this matrix connection, hopefully it just needs checking over, maybe i didnt get it all the way home when installing?
    Either way the TIP has to come off to give access but to be fair as coolant leaks go hopefully this will be an easy one.
  19. tony696
    tony696 Member
    165
    looks good mate keep up the good work
    hope mine goes as well as yours :thumbsup:
  20. MUSH
    713
    12
    Cheers Tony, sure youll be fine mate.
  21. DaveA3
    2,370
    15
    nice one mate glad it went well! good to see it running :D
  22. MUSH
    713
    12
    Good and bad news...
    Whipped the matrix connection off tonight...
    And ive fitted a connector without a rubber seal in it!!
    What a tit, didnt even think of checking. There wasnt even the retaining plastic lip inside, but at least its an easy fix so ill go get a new one on saturday and get it ran up again!!
  23. Dani_B19
    9,343
    394
    Looking good.
    So when you mapping it?
  24. MUSH
    713
    12
    Be a few month id imagine Dan, still got to finish putting it together, MOT, tax, setup suspension, get it ran in blah blah blah.
    Im hoping to make a few shows in september in it, mapped or unmapped
  25. <tuffty/>
    21,675
    4,103
    All been there mate, occupational hazard on these type of builds... always the little things you seem to overlook while putting the car back together...
    Glad she is (technically) up and running though... I was sh*t scared the first time I turned the key on mine the first time around... even though I have done a few head swaps since its always a relief when they start up although I have now come to expect the odd leak as it does happen :)
  26. s17atw
    s17atw Member
    43
    looking/sounding good mate..... wont be long before you up and running
  27. MUSH
    713
    12
    Aye i know bud, im just happy its an easy fix. Hopefully when it pressurises properly i wont find any more leaks!! Think ill be ok though. First start is always a bit hand in mouth, but now its done ive got a bit more confidence to crack on.
    Same happened when i 20v'd my mk2, always a few niggles!! Lol
  28. MUSH
    713
    12
    Not to far off now matey!!
    You sorted your bodywork out yet? Meant to have rang you for a while now, its best you understand im not the best at deadlines or timings lol think the army drove that out of me!!
  29. s17atw
    s17atw Member
    43
    Yes mate all bodywork sorted, went up for front end and side painted ended up getting everything but the tailgate painted!
    All mot'd then had to get the spanners out but Will be on the road soon (hopefully next week)
    running on base map at the moment until it gets mapped
  30. MUSH
    713
    12
    Spanners...? Do tell mate?
  31. s17atw
    s17atw Member
    43
    Getting a new comp wheel fitted to turbo due to for foreign object damage!!
  32. MUSH
    713
    12
    Gutted!!! Think id cry! Take it, it wrecked the wheel? Ill be in touch bud
  33. Andy123
    Andy123 Member
    260
    Nice work Mush- glad it fired up ok! Always wise to have that fire extinguisher close by!
  34. s17atw
    s17atw Member
    43
    just a couple of little chips out of 2 blades on the comp wheel,the said it could be dressed up and rebalanced but i wasnt happy with that so new wheel was fitted...just one of them things
  35. MUSH
    713
    12
    Suppose so mate, the power your pushing you want it to be right!!
  36. MUSH
    713
    12
    Yep chuffed with how it went bud cheers, just need to sort this coolant leak and ill be sorted!
    Im a bit fire conscious, should be considering i work in the industry! Lol got a bigger one in the garage too, and a little one in the glovebox... Lol
  37. MUSH
    713
    12
    Was really thinking i was starting to get somewhere when i decided to nip in to the garage and get a few jobs done, only little ones to be fair, was going to change the pollen filter, refit the plastic scuttle/wipers etc....
    However, got in the car to find the nylon tube for my Stack boost gauge (ive lost it...lol) and found the brake pedal to be a little spongy when i got my foot on it. Was a little gutted, cant stand working on brakes and ive had many brake prolems in the past so i thought i hit it lucky when they bled through ok this time. The only parts of the brakes ive touched (bar bleeding) is the front callipers so i thought id check them out.
    Bingo, found the nearside inside bleed nipple to be seeping a little, so car up again time...
    However even when mega tight, the nipple when under pressure from the pedal still seeped out. It was now that i noticed the fluid that had leaked had buggered the paint on the rear of the calliper and a few other spots. Really couldnt be bothered with stripping it off again so i whipped the nipple out for a quick inspection. Seemed ok but i had some spare so i tried one of them in.
    In my little stash i had some stainless nipples i bought off ebay ages ago. They had a slightly different shaped sealing cone so i thought it was worth a try...
    The nipple on the LHS is the genuine Brembo nipple, and the RHS is the stainless ebay jobby. Anyhoo the RHS nipple when fitted, stopped the leaking, so i bled the line and pumped the brakes up again, no leaking.
    I thought oh poo i might have to sort the calliper if the internal sealing face wasnt sound but luckily the cheap spare nipple saved the day. Woop woop!!
    Got nothing else done though...
  38. day
    day Stoke on Dread
    32
    Great thread Mush...very detailed
    day
  39. AGU-TURBO
    616
  40. MUSH
    713
    12
    Cheers mate, just detailing what im doing, whether it works.....or not :laugh:
    Always matey, today i went and got the required matrix connector, so now thats fitted WITH the rubber seal in place. Also topped up the coolant and then set about stripping the STACK boost gauge...
    And then tried painting the clear lens as S3kev did. It should work fine but if it doesnt ill clean it and try to get a red lens instead.
    Just letting it dry for now. Was going to start on mounting the horns and getting the oil cooler ready to mount but instead i helped me pal take delivery of his mint 80k mile VR6 lump for his mk2 golf.
