multitronic problem setting off
Discussion in 'General Technical / How To' started by leigh a6, Aug 9, 2009.
  1. leigh a6
    leigh a6 New Member
    Aug 9, 2009
    hi all, my mate has just bought an audi a6 2.5tdi multitronic 2003. there seems to be a delay in selecting gear when setting off but its fine when your on the move and selects gears as normal its just when you set off from a stand still it seems to be a pause and doesnt select gear until around 1.5 revs and then it causes a jerk as you pull off.
    thanks
  2. Advert Guest Advertisement
  3. red-line
    red-line New Member
    Jan 23, 2009
    Hi this sounds like your mate may have a problem with the valve body on his multi-tronic gearbox what sort of mileage has the car done? has it ever had the gearbox oil changed? You could also suggest he takes the car to his local audi centre to be diagnosed correctly there are several MVBs that can be read to give better diagnosis good luck.
