MULTIPLE FAULT CODES! NEED HELP PLZ!
seen_ Nov 22, 2010
  1. seen_
    seen_ Member
    40
    Hi Guys,
    Need your help!
    My engine management light came on with a couple of codes. So I changed 2 of my ignition coil packs as this is what the codes were around. This fixed the problem for roughly a month but now the engine management light and several codes have come up! The car runs fine, just a slight lack of power can be felt. Just wondering if anybody knows what it could be? Any help or info would be greatly appreciated. Thanks.
    These are the codes:
    17608 Boost pressure control valve
    17705 Connection turbocharger - throttle valve pressure hose
    16500 Engine Coolant Temp.Circ Range/Performance
    16825 EVAP Emission Contr.Sys.Incorrect Purge Flow
    17584 O2 Correction Behind Catalyst,B1 Limit Attained
    16684 Random/Multiple Cylinder Misfire Detected
    16688 Cyl.4 Misfire Detected
  2. finesse
    finesse Active Member
    2,805
    what suggestions does the Ross tech wiki make in regards to this error
  3. aragorn
    17,877
    687
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    126
    The EVAP system is normally a split pipe. One goes into the TIP, and one comes off the top of the Throttle body.
    Both pipes connect to one of the metal pipes that run along the bulkhead. Check those pipes, and follow them all the way back to the EVAP Canister, found by your header tank.
  5. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,821
    105
    Have you checked the car before for faults?
    They could be old ones stored on the ecu... i would make note of them... clear each one and then recheck in a few days. no point chasing old faults.
    If the codes come back... you have problems,
  6. seen_
    seen_ Member
    40
    thanks guys...atleast thats broken it down to 2 or 3 seperate things that it could be. much appreciated...will pop the bonnet tomorrow and have a look...(Y)
  7. seen_
    seen_ Member
    40
    when i replaced the ignition coil packs i cleared the fault codes and check again after a couple of days and no codes came up...but i have recleared them and will definately check again in couple of days...thanks
  8. seen_
    seen_ Member
    40
    Reading the ross tech wiki notes another cause for some of the faults may be that I have a dump valve fitted?
  9. aragorn
    17,877
    687
    Are you a chav?
  10. S3 Paul
    2,821
    105
    Ignore that post.
    Some people want to hear their turbo ...
    Each to their own,
    However, the Audi ecu isnt happy running a "dump valve" it needs to be something like a forge 007p a recirculating valve.
    i would atleast go back to the standard recirc valve
  11. murran
    murran Well-Known Member
    1,545
    39
    id fit a coolant temp sensor and a set of coils and clear the codes........ and see what codes come back.
  12. aragorn
    17,877
    687
    Atmospheric dump valves are chavvy. There really is no arguement there. It serves no purpose other than shouting "look at me, i have a turbo and i feel the need to let EVERYONE know this"
    Fitting a 007p is completely pointless, when the £26 OEM part does exactly the same job.
    I'd be changing the stat before the CTS, as its more likely to be the cause. He can easily find out which it is by viewing the coolant temp on vagcom and watch what its doing. It will no doubt drop when he drives faster, which is pretty typical of a 10 year old worn out thermostat, and will cause the ECU to pop an "implausible signal" code, because the coolant temp shouldnt be going down.
  13. Welly
    10,696
    126
    But it's shiny.... lol.
    Each to their own mate, you know this. Atmospheric DV not the way forward though, either a 007P, Bailey DV30, or the OEM item will be the ones to fit.
    OP - Your atmospheric DV will be causing some quite substantial compressor stall - not good for the turbo.
  14. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    standard ones crack every 6 months aswell. i had 2 in the space of 6 months that i bought from stealers on my old a3q
