MTM Tuned Audi RS6 Paint Enhancement Detail
butler2.8i Dec 15, 2013
  1. butler2.8i
    butler2.8i Member
    184
    23
    MTM Tuned Audi RS6 Paint Enhancement Detail Products and equipment used Uber microfiber towels Chemical guy’s woolly mammoth drying towel 3m yellow pads 150mm 75 mm Halogen site lights Carpro Fixer Polish Makita rotary polisher Carpro Sheepskin wash mitt Carpro Dlux CarPro Pearl Carpro eraser Carpro Ironx Blackfire Midnight Sun Wax 3m masking tape Meguiars APC Costco microfibre towels Valet Pro PH neutral Snowfoam Britemax Max Clean Shampoo Bilt Hamber clay bar Autosmart Tardis Various brushes Kranzle pressure washer Noodle wash mitt Poorboys microfibre clothes Uber buffing clothes Snow foam gun Chemical guys Jetseal 109 Glass Sealant Britemax Metal Polish Twins 00 grade wire wool Car as delivered by the customer [​IMG] [​IMG] The wheels were cleaned using Carpro Ironx the was then given its first coat of snow foam whilst this was dwelling I went round the car using APC in a foaming head bottle cleaning the fuel filler area and various gaps and grills. The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and the car was washed using the 2 bucket method with grit guards in both buckets and a Carpro lambswool wash mitt. The car was then rinsed off using an open ended hose and I then went round the car with Tardis which was left to go to work before being wiped down with microfibre clothes. The car was then given a coat of Ironx again left to do its stuff before the car was washed down using the pressure washer. Engine bay was cleaned with Megs APC a various detailing brushes before being rinsed with the pressure washer The car was clayed using citrus bling and water mix (10 to 1) and a Bilt hamber soft clay bar which helped to pull more contaminates from the paint work it was then rewashed using the same method and dried using the woolly mammoth. Snow Foaming [​IMG] [​IMG] [​IMG] Condition Of The Paint Under The Lights [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] I then taped the car up and went round with various yellow 3m pads and Carpro Fixer polish, each panel was given a wipe down with Carpro eraser after polishing to check finish and remove any polishing oils. [​IMG]
  2. butler2.8i
    butler2.8i Member
    184
    23
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Audi-Rog and MrBones like this.
  3. butler2.8i
    butler2.8i Member
    184
    23
    Engine Bay dressed [​IMG] The car was given 2 coats of Blackfire Midnight Sun Wax leaving wax t approx 60min between each coat again buffed using Uber buffing towels The plastic trim was dressed using CarPro Perl which is a cracking product which a little goes a long way and gives a stunning finish. After this I cleaned the glass and gave them all 2 coats of glass sealant The alloys and callipers were sealed using 2 coats of Chemical guys Jetseal 109 and dressed the tyres using the Valet Pro tyre dressing [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] Finished shots [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] Here’s a link to my facebook page http://www.facebook.com/NorthEastCarCareUK
  4. 347
    347 Active Member VCDS Map User
    362
    59
    great work there , it certainly made a big improvement !
    nice car as well , not sure about them bonnet louvers but I'm sure they serve the purpose
  5. ijgreer
    ijgreer Member
    142
    19
    Looks great! The effort was worth it!
  6. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    885
    Lovely job. Bet this shifts. Dont see alot of MTM tuned ones.
  7. s3Easty
    s3Easty Member
    108
    Awesome motor and great result..like the Ford Capris in the reflection shot..
  8. butler2.8i
    butler2.8i Member
    184
    23
    Cheers Guys
  9. the_cueball
    the_cueball Active Member
    494
    218
    43
    looks good mate, keep up the good work...
  10. butler2.8i
    butler2.8i Member
    184
    23
