Mr Muscle Turbo clean quick question
Ian2012 Nov 27, 2013
  1. Ian2012
    Ian2012 Active Member
    473
    29
    I am having trouble getting the egr pipe off, can i use a length of hose small diameter and poke it down the tube as far as it will go or does it have to go deeper?
    ta
    Ian
  2. mikeygulley
    mikeygulley Member
    30
    I wouldn't risk it for a chocolate biscuit mate. You need to see the tube goes in the right direction as shown in the guide.
  3. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    its easier if you take the exhaust off the turbo and go in from the back ;)
    remove the exhaust from the turbo and take the gaskets off trace around the gasket on to some card and cut it out bigger then the gasket poke the three holes in then put it over the bolts on the turbo so it seals it
    put the gaskets back on followed by some large nuts followed by the OE nuts to hold it all on poke a hole through the card insert some sort of pipe and go past the vanes and fill it up
  4. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,365
    2,335
    How about take the turbo off strip it and put it back on. Mr Muscle might get it working for a bit but it's only a temporary measure.
  5. Ian2012
    473
    29
    i haven't the time at the moment, and doing a pipe down the egr pipe has i hope worked
