MPH clocks
ja5on21 Dec 20, 2009
  1. ja5on21
    ja5on21 New Member
    i have a audi a4 03 sport with the clocks that just show miles to next fill is it possible to get the se clocks fitted to show mpg etc...
    cheers jason
  2. quattrojames
    14,050
    578
    Welcome to the forum Jason :sign_welcome:
    Have a search for DIS Upgrade or similar in here, there are loads of posts on this - it can be done relatively simply yes.
  3. ja5on21
    ja5on21 New Member
    cheers james
  4. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Welcome Jason. Have you not got the function on the right hand stalk ??
  5. chrisash32
    chrisash32 Member
    573
    Hi Jason,
    I am just about to order all the parts today to do this on mine.
    But i am also going to fit cruise control at the same time.
    If you don't want cruise, its a fairly simple job and you will only need the right hand stalk (About £70 from pjmspeedy on here).
    I would put the part number on, however it depends if you have a Saloon or an Avant.
    If you do want cruise as well, but don't have a multi function steering wheel... you will also need a new steering wheel control unit. (this is where it gets slightly complex) as the standard one without MFSW does not support cruise or MFSW. Not impossible though, just a bit more expensive.
    Hope that helps!
    Cheers,
    Chris
  6. ja5on21
    ja5on21 New Member
    cheers for the help lads mine is a a4 2003 saloon would you know the part number cheers jason
