MPG on long run after remap
pink.teg Apr 5, 2012
  1. pink.teg
    pink.teg Member
    170
    hi all
    had my remap about 3 weeks now but only had the chance to take her on a 300 mile run the other day
    beening a 1.9tdi quattro it will be alittle less then the fwd cars but the computers saying 45mpg
    now thats good no!!!!!!!!..doing 80mph and above ..
    are you quattro owners getting the same ...:racer:
  2. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    59
    sounds about right for a 1.9TDI quattro on an 80mph+ cruise... I'd need to be gently nurturing it back and forth between 65mph and 75mph to get that sort of economy! Who says the V6 TDI's are faster ;)
  3. quattrojames
    14,050
    576
    Check it on paper before you go believing the DIS too much!
  4. benjie
    benjie Well-Known Member
    1,223
    304
    I get v similar readings with my remapped 1.9quattro. Drive like a pensioner and I can get the DIS to show 54mpg! Though that's grandpa driving. I also subtract 10% from the DIS as I have worked it out tank for tank a few times and it turned out to be a few mpg less in real life.
  5. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    You should get almost the same mpg on a remap as stock if you drive at partial throttle ie don't hammer it. It's only the WOT and heavy right foot driving that is different , if you drive sensibly mpg should be the same.
