Mpg gauge information
joebickerton89 Dec 22, 2012
  1. joebickerton89
    joebickerton89 Member
    123
    hey everyone a bit of a weird question but how often do your mpg gauges go up and down? i just done a 30mile round trip with mostly cruising but on the way home giving it some stick just to see if it changed but it didnt :/ and it didnt change at all apart from going up .1 where as i think it should be changing up or down every 5minutes or less wether it be going up or down but it takes like 20minutes if im constantly driving to change :/ any ideas?
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    Reset the trip computer by pressing and holding the button under the stalk.
  3. joebickerton89
    123
    just about to go do it now mate il let the results of it be known in a bit
    Westy likes this.
  4. joebickerton89
    123
    ive reset it mate and it seems back to how it should be. it seemed to of got stuck before :/ would what it was reading on the trip computer of affected the real mpg of the engine?
  5. MingeBlue
    MingeBlue Member
    112
    Its the 'average mpg' so the more miles you have driven since last reset the more miles you will have to drive in style that would change it to see any impact. It appears to be correct now after resetting as the average is worked out on fewer miles so you see more of a shift with less driving. Its how averages work so the computer was right all along. It wouldnt of impacted the cars running if it had I would be the first to run to my car and hack it so the DIS showed 100mpg :).
  6. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    if it was the average mpg over 1,000,000,000,000,000,000,000,000,000,000,000,000,000 miles then driving another 10.23 miles isn't going to noticeably change the average... your car is fine
