MPG anger
wuta3 Jun 5, 2013
  1. wuta3
    wuta3 Well-Known Member
    1,124
    347
    Right, so the recent "what MPG u get bro?" thread has made me mad. I get about 250 miles a tank (brimmed, reset mile counter). I can only manage 30mpg when coasting down hill (journey avg). Typical town driving is about 16-19. After an hour driving, trying my hardest to get the highest mpg I can on country roads + motorway I struggle to see 25mpg.
    Any thought on what could be causing it? Broad question I know, but most S3/2.0tfsi cars seem to be doing much better than me!
    Im not too fussed, just want to make sure the engine doesn't have an issue. No faults logged via Torque and everything runs fine otherwise.
  2. box500
    box500 Member
    163
    I get 23mpg to 25mpg all day long at 90mph
    Your MPG does seem a bit low if you've being driving for economy..
    I assume you're not a big fat knacker and that you don't lug loads of heavy kit around either ??
    Brakes binding slightly ?
    Tyre pressures
    decent airfilter and plugs ?
    Have you tried banging in a dose of something like cataclean ?
  3. wuta3
    1,124
    347
    Nope not a big fatty, just me in an empty car :) Tyre pressures checked every 2 weeks, plugs changes less than 2k miles ago and made no difference, air filter isn't fresh, might check this.
    box500 likes this.
  4. TDI140
    TDI140 Well-Known Member
    1,624
    174
    Maf sensor
    air filter
    fuel filter
    boost leak
    plugs
    there tha main issues i can think off that can effect mpg
  5. wuta3
    1,124
    347
    I think it most likely will be induction either air filter/boost leak. Better go check and change.
  6. TDI140
    1,624
    174
    Im struggling to understand what you said pal ?
  7. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    250 from a tank, I used to get 450 from a 2.8 4mo, now get 650-700 from 1.9tdi .
    Definitely change your air filter,fuel filter and run some injector cleaner through it as well.
  8. wuta3
    1,124
    347
    Yes you would struggle to guess im actually english by the state of that sentence
  9. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    U might as well add a remap to that as ur mpg can't get any worse surely m8 lol ;)
    S. and wuta3 like this.
  10. wuta3
    1,124
    347
    lol true, but ... dont want a remap until im sure im in tip top condition and im very slowly gathering stage2+ parts so not bothered about stage1 remap.
  11. S.
    S. Well-Known Member Team Ibis TFSI Owners Group Audi S3 quattro Manual
    1,986
    540
    hm...i get similar mpg...
  12. wuta3
    1,124
    347
    Yea but you are stage 2+, I think that's acceptable with a HPFP/RS4 FPR on top of being an S3 LOL
    I'm just pootling along on 200bhp/K03 atm.
  13. Turbo jay
    Turbo jay Leather repair specialist
    577
    69
    I've got the same car and doing my daily commute, I get 300 miles out of a full tank.
  14. S3Alex
    10,641
    4,700
    Lol.
    I get 28mpg now but I do drive like Miss Daisy.....occasionally.
  15. wuta3
    1,124
    347
    Exactly :) ... I tell you what ... this thread should have been called "hey all people running higher power, come in and tell me how much better your MPG is than my stock car and make make rage even more and sad at the tought of my mpg when I get my stage2+ stuff together"
    :haudrauf:
    haha
    Zak0123 likes this.
  16. S3Alex
    10,641
    4,700
    It's just to make you go and get all the mods done.
    All part of a conspiracy!
    Brodster likes this.
  17. wuta3
    1,124
    347
    I suppose going BT is the ultimate fuel saver then LOL ;)
  18. S.
    1,986
    540
    98% of my driving is arround town, and mostly on rush hours. so i don't find it that bad actually. and i like to press the loud pedal :D
  19. andrecc
    andrecc Member
    253
    £20 gives me around 85-100miles city driving is that good?
  20. S3Alex
    10,641
    4,700
    You got it!
    How do you think I convinced myself to do it.
  21. S3Alex
    10,641
    4,700
    I'd say most of mine is out of town,and fairly constant speeds(apart from the occasional opportunity for a blast),so that's why mine "looks" quite good.
    The trackday last year got it down to way less than that.
    It's very easy to use the torque and low rpm to save fuel if you want,and still have the power if you need.
  22. wuta3
    1,124
    347
    You sir, are a danger to my wallet.
  23. S3Alex
    10,641
    4,700
    Once again,you see what happened to me when I joined this place and VAGOC.
    Both have a LOT to answer for!
  24. wuta3
    1,124
    347
    Yea im used to it from other expensive hobbies acquired from forums (audio :( ). Most other forum users don't provide handy tips on self justification and dealing with the missus tho ;)
    Btw, bit OT but have you any exp of the Neuspeed p-flo? You had the VWR? The p-flo seems like a bargain. My air filter needs upgrading so thinking I might as well intake rather than just slap a new panel filter in the box.
  25. S3Alex
    10,641
    4,700
    Audio.....another favourite here as well,although it's taken a bit of a back seat(!) recently,but I do love tube amps and Krells.
    Anyway....The Neuspeed gets a good rep generally,and I think that if you want the last few grams of air you'd go with the latest intakes,but you'd be unlikely to be disappointed with the Neuspeed.
    CAIs are essential for higher levels of tune,and I don't think there's any way around that as the stock intake piping is quite restrictive.
  26. wuta3
    1,124
    347
    Tubes, the thorn in my side, stabbing my bank account with their glorious sound/cost (sigh) currently running TS7236 and some Mullards in a headphone amp. Massive bang for buck. PM me if you want another hobby, high-end headphone audio is amazing.
    Yea i'd go with the Neuspeed super-extendo-tube-CAI-attachment if I needed it later for CAI. Saves forking out the whole lot at once.
    At like half the price of the others, the p-flo seems cracking value, just ... must be something wrong with it :S lol
  27. S3Alex
    10,641
    4,700
    I know....PM on the way.
    wuta3 likes this.
  28. gazzer_s3
    gazzer_s3 Member
    69
    Averaging approx. 26-28mpg mainly A roads to & from work but its only 7 miles each way with a fair bit of stop start, so not to bad?
