MOTs Fog lights and fuses...
benyon Mar 21, 2014
  1. benyon
    benyon New Member
    2003 A6 C5 saloon.
    Hi all, I have just picked my car up from being MOT'd today and the only issue was the fog lights were u/s. The mechanic replaced fuse 36 (I think) and now the rear fog works, however the fronts still don't!
    Is there no requirement for front fogs to work for an MOT?
    Are the front fogs on the same fuse as the rear fogs?
    If so what else do I need to look at to get the front fogs working?
    Thanks in advance!
    Benyon
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    Have you simply checked the bulbs?
  3. benyon
    benyon New Member
    I haven't, but I was assuming the bulb warning would have come on if it was bulbs, again assuming that works on the fog bulbs...?
  4. wesmaster
    wesmaster Member
    300
    20
    Front fogs not MOT failure. only must have O/S/R or Central rear.
  5. benyon
    benyon New Member
    Ok that's good. Do you know if front and rear foods are on the same fuse on a 2003 1.9tdi?
