MOT Fail on Lamda and fast idle test (so close!)
jcb Apr 4, 2012
  1. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    OK so its an A6 2.8 but no-one lives over there so I am asking here!
    MOT at Kwikfit (yes I know, first mistake but they are £20 cheaper than anyone else so the retest is basically free!)
    Lambda and CO failed but so unbelievably close to the limit!!
    0.022 on lambda first fast idle
    0.001 on lambda on second fast idle!
    0.030 and 0.044% over on CO on fast idle tests
    I have a small leak just before the CAT, that wouldn't change anything would it?
    Going to log Lambda measuring blocks and voltage now and swap the plugs out
    any suggestions?
    its very minor
  2. aragorn
    18,036
    725
    any exhaust leaks can effect lambda reading and cause a rich mixture, so get some gun gum round the small leak if you can to seal it up
    Then give it absolute death for 10 mins and get it back to kwikfit with it red hot for another test.
    The cats look tired though, unless they were cold?
    The guy often holds the RPM's up around 3k for a good couple of minutes if it fails to get some heat into the cats, did they do that?
  3. jcb
    4,132
    13
    no, its KwikFit!
    the only think they are interested is selling other ****
    £4.99 for a sidelight bulb? "no thanks I get my own cheers"
    am on the exhaust leak and it was only really present when revving so possible.
    pulled 4 out of 6 plugs and they looked fine, bit of a coating but nicely brown and dry
    probably needs new ones anyway so will do that and get it back asap
  4. Mackers
    Mackers Member
    291
    as above, seal ya exhaust (it would effect the emmisions) ya could try fuel treatment, or as also stated, give it "an itailian tune" and blast and keep it running when there so it's RED HOT. :D
  5. jcb
    4,132
    13
    would an inlet vacuum leak cause this?
    The Lambda is showing its lean right?
  6. aragorn
    18,036
    725
    very slightly lean yeh.
  7. jcb
    4,132
    13
    just replaced all the horrible fabric covered hoses around the in inlet with some nice silicon I had.
    next the exhaust leak
    not doing plugs, cant be arsed and they look pretty good as it is.
    finger crossed
  8. murran
    murran Well-Known Member
    1,545
    39
    id say that exhaust leak is causing the lambdas to see a weak mixture when there isnt one.
  9. jcb
    4,132
    13
    am seriously struggling to stop the exhaust leak.
    smothered in gun gum, wrapped in exhaust bandage and under load even after hardening it has blown through a tiny amount again.
    there must be some serious back pressure in front of the CAT
    Anyone know of any super strong exhaust bodge?!
  10. aragorn
    18,036
    725
    Weld? :p
  11. jcb
    4,132
    13
    yeah that is what worries me.
    it is right up front right next to the hanger. its a front pipe out job if it is welded!
    cant see a fecking thing on these engines.
    is a front pipe removal an engine out job on a V6 like every other engine out job!?
  12. murran
    1,545
    39
    is this a 2.8 30v v6? no its not an engine out job. is it the 2 flexible bits infront of the cats that are blowing? a decent exhaust place can remove the front pipes and weld in new flexible sections. only danger is one of the three manifold studs snapping off.
    ive done a couple of these at work. much cheaper than new cats!
  13. jcb
    4,132
    13
    Woo Hoo!!
    repair on the exhaust, a new CTS and some sidelights! MOT passed.
    now for the painful experience of taxing a 2.8!
  14. aragorn
    18,036
    725
    Shouldnt be any more expensive than the 1.8T if its pre-2001...
  15. jcb
    4,132
    13
    ha, try £240!
  16. aragorn
    18,036
    725
    Yep, 1.8T is the same!
