MOT Fail! (Now passed!)
jojo Aug 25, 2012
  1. jojo
    28,935
    3,587
    So I had my MOT yesterday and it failed!
    The main thing was a broken rear coil spring, snapped right at the bottom where it sits in the cup, you can't even see it, but the MOT tester had a feel round then showed me! Quite disappointing, considering the springs have only covered 30k odd miles, but they have been on the car for 8-9 years, which lives in the garage 95% of the time! New springs ordered anyways...
    Anyways, as the MOT operated the washwipe, my car decided to lose all it's washer fluid, I think he may have had the headlights on to operate the headlamp washers aswell? Thoughts of where it could be all coming from? It's all leaking out under the front bumper on the driverside. My searches have only bought up sticky headlamp washers in the cold when they freeze up and don't go back down fully, mine were all the way down and sitting flush with the bumper!!
    Regarding other aspects of the MOT test, my S3 breezed through the Emmissions test, and brake test, but I have to adjust the handbrake lever, as I've never adjusted it in 10yrs of ownership! He just said it was a bit high.
    So I have 10 days to get the springs and fit them on! lol, not helped that it's a bank holiday weekend, so I'm not sure when they will arrive!
  2. aragorn
    18,491
    855
    maybe the headlamp washer pipe has come off?
  3. jojo
    28,935
    3,587
    Bumper off job isn't it?
    Great!
  4. Dani_B19
    9,336
    391
    Yup, only takes 2 mines mate, either pipes bust of the t's died.
    ROBBerto84 likes this.
  5. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    This but it takes minutes Joe.
  6. thegoal007
    thegoal007 Another S3 owner....
    805
    26
    Broken rear spring - that would have escaped many a good mot'rs !
    on the one hand it's good that they are thorough, but in the case of rear broken spring - come on, you were probably completely oblivious to the fact. I bet anyone buying an S3 wouldn't even have checked that !
  7. jojo
    28,935
    3,587
    This MOT guys is sound, as I'm waiting on site, he takes me to the car for things that are major, like the rear spring on this instance.
  8. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Very common though Goal007 I've had the same and my MOT garage say they always have A3/S3's fail with the same problem
  9. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    What springs do you have on your car jojo. It's wierd how it's common even on non original items. Happened to Gops s3 aswell and they were h&r's. As for oem springs mine failed its mot a couple years ago for the same reason.
  10. PaulRS3
    PaulRS3 Well-Known Member
    1,226
    153
    Broken rear coil springs are common on S3/TT
    I had one go on my previous S3, when it snapped it was parked and went with quite a ping as I was walking back to the car.
    I also had about 1" snap off the end on one of the front springs causing a mot fail. So that was all 4 springs replaced over 9 years / 70k miles ownership.
    Springs were circa £65 each for the genuine Audi Quattro GmbH optional suspension my car was fitted with.
  11. jojo
    28,935
    3,587
    Eibachs
  12. superkarl
    superkarl MAN OF STEEL
    9,554
    2,453
    only so good a steel spring can be against fatigue of so many miles and years.
    the rear spring on our cars are pathetically small too
  13. jcs356
    jcs356 Brum brum
    2,734
    70
    You've also got to factor in the terrible state of our roads and the proliferation of speed bumps and no wonder they snap!
  14. s33nyboy12
    s33nyboy12 Well-Known Member Team Ibis Team V8 Audi R8 s tronic
    1,488
    203
    I had these problems with mine fixed them pre mot mate. Front bumper off and it's a pain to get your hand in connect it back to the joint for the washer. There is a front bumper removal guide on here and I'm sure I used one off here to do the rear springs.
    All in all to do both and the top mounts with bearings took me 6 hours as a novice..... Not bad I thought.
    Cheers, Sean
  15. jojo
    28,935
    3,587
    I don't think my ventures out on track helps neither! :laugh:
  16. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,130
    356
    Im sure you will have this sorted soon, going to use the track at ADI to christen those new springs?
  17. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    60
    If it suddenly dumped all the washer fluid, i'd say its a pipe...
    If it was a trickle or a drip its most likely the headlight washer units.
    I had one start to leak last year, & the other at the start of this. I looked at them to see if the seals could be replaced on the plungers, but doesnt seem like it as they look like sealed units.
    Cant remember the cost of replacements, but £180 springs to mind...
  18. jojo
    28,935
    3,587
    I hope so! Are you joining us on track?
  19. Jay A3
    2,130
    356
    No not this year...
    Still getting it ready :weight_lift2:... bring on the rocky montage
  20. Nilz
    11,356
    894
    Jo as you mentioned the handbrake, I have been meaning to ask for ages, how many clicks does the usual S3 take to be on full?
  21. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    187
    Never thought about that nilzy I always hold the button in till its tight then go 1 click lol
  22. Lewis583
    956
    91
    Don't forget Jo it's 10 working days not including Bank holidays so that gives you a bit more time to get it done :icon_thumright:
  23. jojo
    28,935
    3,587
    I just do what Chris has described below, I rarely pull the handbrake without the button, relying on the clicks. Plus the S3 is suppose to be self adjusting, as the handbrake winds the piston out when you operate it. Since my S3 is over 10 yrs old, it's probably a sign of seizing calipers, but I have a pair of new ones spare.
  24. jojo
    28,935
    3,587
    Cheers for this bit of info, every day helps with, so I just need my springs to arrive sharpish, and a dry day to fit them. I think I'll just do the rears to pas the MOT first, then swop the fronts over later on, as I'm not actually road legal at the mo'.
  25. [Dave B]
    [Dave B] Daddy
    2,027
    145
    2 clicks for me, but that's on fresh rear discs and pads...
  26. Gops
    3,198
    666
    I think it's bad corrosion on the rear springs. Mine were appalling! I'll always urge people to check them every now and then if they are a few years old. Despite 3 emails to h&r, I never received an email back - that's ****!
  27. jojo
    28,935
    3,587
    I've found out I can order just the rear Eibach springs! But they cost more than a full set of Apex ones, so Apex here I come!!
  28. jojo
    28,935
    3,587
    So it's MOT round2 time tomorrow, just changed the rear springs for the pass, will get on the fronts at the weekend hopefully!
    Eibachs out!
    Apex in.
  29. Snash7
    Snash7 Member
    84
    Looks good dude good luck with the MOT how hard are the springs to fit.
    Cheers Grant
  30. jojo
    28,935
    3,587
    Rears are a piece of cake, took me around 2.5hrs on axle stands outside my house having not done it before. Fronts are a bit more tricky, you need to take the whole strut out and spring compressors etc. I could probably do it half the time if I was using a ramp.
  31. Nilz
    11,356
    894
    Well done Jo, let us know how it goes.
  32. jojo
    28,935
    3,587
    5 minutes visual inspection and pass!
    Good for another 12 months, and I can buy my roadtax!
  33. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Any pics of the ride height with the Apex springs on?
  34. jojo
    28,935
    3,587
    Not yet, I only have the rears fitted. I can tell you they are 5-10mm lower than the Eibachs, and that was straight after I fitted them, they've not settled yet! These maybe the lowest option for springs only from my experience!
  35. jojo
    28,935
    3,587
    Here's a pic of the rear.
  36. Nilz
    11,356
    894
    Road Tax, you may as well sorn it....the amount it sees the road...lol
    Good result btw :)
