MOT changes from april 2012
FranA3 Dec 30, 2011
  1. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,246
    340
    MOT test for cars
    New mandatory test items from 2012
    [​IMG]If you've been happily ignoring a warning light because it's not checked in the MOT you could be facing an MOT failure and an expensive repair bill in 2012 because of changes to the test.
    The Department for Transport is adding a number of new mandatory test items to the annual MOT from 1 January 2012 to comply with a revised European testing directive.
    The aim of the revised directive (2009/40/EC) is to harmonise minimum test requirements across Europe and make sure the test reflects the electrical/electronic complexity of modern car safety features.
    VOSA, the government agency responsible for the MOT, has indicated that 'failures' relating to the new test items will be treated as 'advisories' in the first three months. This means that if you have any of the following problems with your car you've got until the first MOT renewal date after 1 April 2012 to get it fixed.
    The main changes from 2012
    Electronic parking brake
    Electronic parking brake controls are now included and must be present and not inappropriately repaired or modified - repair obviously likely to adversely affect the roadworthiness of the vehicle or modification that has seriously weakened the component.
    (The 'inappropriately repaired or modified' check is to be applied to a wide range of systems and components throughout the vehicle.)
    The car will fail if an Electronic Parking Brake warning lamp is illuminated to indicate a malfunction.
    Electronic Stability Control
    Checks of antilock brakes will be extended to include Electronic Stability Control if fitted. The tester will check for the presence and correct operation of the ESC malfunction warning light together with looking for obviously missing, excessively damaged or inappropriately repaired or modified components and electrical wiring, as well as an ESC switch missing, insecure or faulty.
    Warning lights
    As well as electronic parking brake and electronic stability control warning lights (where fitted) the MOT test will also include checks for the correct function of the following, where fitted;
    • Headlight main beam warning light
    • Electronic power steering warning light
    • Brake fluid level warning light
    • Tyre pressure monitoring system warning light
    • Air bag warning light
    • Seat belt pre-tensioner warning light
    Steering & suspension
    The new test includes a check on the presence and correct function of the steering lock where fitted as standard.
    Missing, or split/damaged dust covers on steering and suspension ball-joints will result in failure if they will allow dirt to enter the joint.
    Power steering fluid level must be above the minimum level indicated on the reservoir.
    Lighting
    Products on the lens or light source that obviously reduce the light's intensity or change its colour will become a reason for failure – applies to front/rear position lamps, registration plate lamps, stop lamps, rear fog and direction indicators,
    Headlight requirements are updated to take account of the particular characteristics of High Intensity Discharge (HID) lamps.
    HID headlights can cause dazzle if they are dirty or aimed too high so car manufacturers must fit headlamp cleaning and levelling systems. A car will fail if a mandatory headlamp cleaning or levelling system is missing, doesn't work or is obviously defective.
    Vehicles fitted with aftermarket HID systems must also be fitted with properly working washer and levelling systems.
    If a headlamp bulb is not seated correctly the resulting beam pattern will be indistinct and this will result in a test fail.
    Electrical wiring and battery
    An insecure battery will be a reason for failure as will a battery that is leaking electrolyte.
    Visible wiring that is insecure, inadequately supported or likely to cause a short will also result in a failure as will wires bared by damaged insulation.
    Trailer/caravan electrical socket
    There will be a basic security/damage check of 7-pin sockets,
    13-pin sockets will be subject to a full electrical connectivity check and incorrectly connected or inoperative circuits will result in failure.
    Tyres
    Tyre pressure monitoring systems fitted to vehicles first registered after 1 January 2012 must be working correctly and not indicating a malfunction.
    Supplementary restraints
    The vehicle will fail the test if any airbag fitted as original equipment is obviously missing or defective.
    A seatbelt pre-tensioner fitted as original equipment but missing or that has obviously deployed will be a reason for failure.
    Seatbelt load limiters that are missing where fitted as standard or folding webbing type limiters that have obviously deployed are also reasons for failure.
    The vehicle will also fail if an SRS malfunction light is missing, not working or indicating a fault.
    Speedometer
    The car will fail if a speedometer is not fitted, is incomplete, inoperative, has a dial glass broken/missing or cannot be illuminated.
    Seats
    It must be possible to secure the driver's seat fore and aft adjustment mechanism in two or three different positions. On electric seats the motors must move the seat fore and aft.
    Doors
    A rear door that cannot be opened from the outside using the relevant control is a new reason for failure.
    Doors must be easy to open and close – hinges, catches and pillars will be inspected.
    Towbars
    Inappropriate repair or modification to the towbar assembly will be a reason for failure if judged likely to affect the roadworthiness of the vehicle/trailer.
    Exhaust
    A catalytic convertor fitted as original equipment but missing will be a reason for failure.
    Fuel system
    Damaged or chafed fuel pipes will result in failure.
    (14 October 2011)
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,164
    1,123
    How will they test the ESC?
    Plant their the go peddle in to the carpet and make sure it don't wheel spin?
    Lamin-x is going to have issues?
    How will they test the head light washer system? Turn on lights, start the engine and keep their hand on the screen washers till the head light washers fire?
    I assume they are just going to do a visual inspection and not pull panels off looking for cables?
    How are they going to test air bags? I assume allot of their 'tests' will be "is the light on?". "No" Pass!!.
    No fitting duel stage air bags to a single stage car and trick the light?
    How will they test or see pre-tensioners? Not all are visible with out removing the seat of panel?
    Thats all the modders with flush back doors that's open via a remote switch failed then?
    Time to gut the cats!!
  3. FranA3
    7,246
    340
    all electrical systems must work as they should i.e. when you turn on the ignition they must come on and go out after a time like they do out of the factory , yeah time to rip off all those lovely tinted headlights i feel , as for hid's they have to have self levellers and washers they don't have to be in a projector lens as i first thought because not every manufacturer has put them in projector lens'
  4. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,326
    188
    Just bought some Lamenex...Glad i dont have MOT's :)
  5. FranA3
    7,246
    340
    yeah you may be lucky but I'm not sure if there might be like stop checks for things like that you will more than likely be all ok tho you jammy so and so lol at least you have a few years till the first one eh
  6. paddy
    5,326
    188
    Ah yes but the law and MOT's are to different things.
  7. Khufu
    Khufu Well-Known Member
    5,704
    31
    With regards to the lamin-x, the tints would have to be pretty dark to fail (over 50%?) i'm sure most peoples will be ok.
    IIRC South of the border VOSA have the power to pull a vehicle over and if not happy issue a prohibition notice on it whether its due an MOT or not, currently in Scotland VOSA require the police to stop a vehicle.
  8. FranA3
    7,246
    340
    yah thats true bud , i can see some traffic police getting a bit ott tho and pulling over all kinds of cars
  9. ScottD3
    15,164
    1,123
    As long as its the miss aligned blinding fecker on the road HIDs, I'll be happy.
  10. FranA3
    7,246
    340
    lol same here man they are so annoying aren't they
  11. sinic
    sinic Audi WAudi
    250
    A lot of members have fitted aftermarket HID's.....but how many have fitted washer kits ?
  12. ScottD3
    15,164
    1,123
    If you ever get out and approach them, all they ever say is "Its hids mate, Nothing I can do".
    Fit the correctly and get your lights aligned might be a good start.
    I know of one member.
    I wonder if it has to be OEM washer or just any set of windscreen washers mounted in the bumper, pointed in at the lights will do.
  13. FranA3
    7,246
    340
    i suppose that any washer would do it so long as it was there to clean the headlight they couldn't say it wasnt
  14. fangio
    fangio Well-Known Member
    1,513
    180
    The bigger concern will be the self-levelling.
    And I believe it starts next month........ i.e. Sunday!:(
  15. Khufu
    5,704
    31
    a lot of the new changes are advisory for 6 months (they have finally decided this a month before changes are due!!!!) before they become a fail so there's time yet :icon_thumright:
  16. FranA3
    7,246
    340
    luckly I've got till sept till mine is due I've got the traction control / emissions and the airbag lights all on so have to get them all sorted
  17. fangio
    1,513
    180
  18. antwan
    antwan Member
    85
    Aftermarket HID's, the MOT only covers items fitted at the time of test, so if ordinary H4/H7 bulbs are fitted at the time of test, the new regs dont apply..........:rulez:
  19. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,113
    354
    So it means that someone who has a track car but still keeps it road legal and removes front airbag to fit sport steering wheel will fail mot?:huh:
  20. ScottD3
    15,164
    1,123
    That like with any MOT EVER.
  21. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    Not so... the regulations dont specify self levelling. only that the a levelling device is fitted and operational... :sly:
  22. AR-rkon
    1,913
    166
    Love the ingenuity there mate :D
  23. fangio
    1,513
    180
  24. paul20v
    paul20v Audi fanatic
    1,113
    Hi
    sorry its 3 months and it all comes into force in its entirety .
  25. paul20v
    1,113
    sorry they do state self levelling but as its been pointed out the word MAY in the below text sort of makes the whole thing a pointless exercise VOSA does it again ......................
    Vehicles equipped with High Intensity Discharge
    (HID) or LED dipped beam headlamps may be fitted
    with headlamp washers and a suspension or
    headlamp self levelling system.
    Where such systems are fitted, they must work;
    however, it is accepted that it may not be possible
    to readily determine the functioning of self levelling
    systems. In such cases, the benefit of the doubt
    must be given.
    Headlamp washers may work in conjunction with
    the windscreen washers (when the dipped beam
    headlamps are switched on) or by a separate
    switch.
    HID lamps may be identified by:
    • taking a few seconds to reach full intensity
    • having a bluish tinge to the light
    • having an igniter module/inverter behind the
    headlamp
    • having ‘DCR’ marked on the headlamp lens.
    HID headlamps use high voltage and extra care
    should be taken when inspecting these items.
  26. Baffles
    Baffles Active Member
    229
    44
    Anyone think I will run in to issues with my head lamp washers not working? When I changed to the S-Line bumper it had washer jets installed - but i haven't had them connected as I need a different tank, and do not have Xenons.
    Hopefully they can see that..
  27. mike foster
    3,967
    Shouldn't be a problem if you don't have xenons
  28. Goosey
    Goosey Member
    61
  29. Paul76R
    Paul76R Member
    150
    checked up on the new MOT yesterday as mum's rather elderly car is due it MOT this week, from what i gathered the new rules came into force on 1st Jan 2012?
  30. Goosey
    Goosey Member
    61
    some did yes, a lot don't come in till april
  31. BBlackburn
    BBlackburn Member
    395
    9
    I'd ask wherever you take your car about that I always thought that if they were there they need to work? Obviously If you don't have xenons though they shouldn't be checked or should they?
  32. Goosey
    Goosey Member
    61
    only cars with HID's will be checked, not halogen
  33. c_w
    c_w Well-Known Member
    1,163
    87
    Usually the headlamp washers are intelligent and don't always operate, sometimes it's every 5 wiper washers etc. I also think that if you did fit washer jets to the bumper you could plumb them in to the wiper washers as has been mentioned.
    With regards the comment about a track car without an airbag, the rules are stating "obviously missing", which means to me a deployed airbag has not been replaced. An aftermarket wheel that doesn't have an airbag by my interpretation would be ok - that is as long as the airbag light is also not on to ensure the rest of the system maintains functionality.
  34. murran
    murran Well-Known Member
    1,545
    39
    nope, an aftermarket wheel without an airbag IS a component (the airbag) "obviously missing". durrrrr......
  35. Artimus
    Artimus Shortback
    2,017
    485
    Bump:
    so how did this go? any clarifications\ramifications?
  36. kanecullen89
    kanecullen89 Active Member
    569
    160
    43
    I'm not sure if the 'check of the gaiters around the steering and suspension check to make sure they're not split as to allow dirt to get in' is one of the new ones but I had my mot yesterday and it failed due to the cv joint gaiter being split which could allow dirt particles in.
    That was the only fail and only cost £60 fitted so not all bad.
  37. mike foster
    3,967
    CV boots have always been part of the MOT as far as I know.
  38. kanecullen89
    569
    160
    43
    Ah fair enough. Learn something new everyday. I'm still over the moon with that mot. Expected a lot worse!
    The Audi lives on for another year
  39. Goosey
    Goosey Member
    61
    inner ones never used to be, they all are now.
    as for the bulk of the changes, it's still not happened yet but we knew that was going to be the case.......
  40. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    I'm in favour of the HID requirements. I've seen so many cars on road with after market HID's which clearly dazzle because they use the wrong projectors in the headlight assy...
