More window wiper woes...
danzman2002 Sep 12, 2013
  1. danzman2002
    danzman2002 New Member
    26
    Hi all,
    After eventually getting my B7 Aero Wipers & Wiper Arms on my B6 Avant - the drivers side one misses a whole chunk of the windscreen when it's wet!
    When the wipers are halfway up the windscreen, you can see an arch where the wiper rubber itself completely loses contact with the windscreen.
    With my MOT due in a week, I'm a bit worried about it!Is the problem likely to be caused by the wiper, the wiper arm, or because the B6 & B7 windscreens are slightly different shapes?
    If it's the wiper arm, is it possible to 'adjust' the tension on it, to push the wiper onto the windscreen? (When you push it by hand, it does make contact)
    Many thanks,
    Daniel
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,246
    189
    I think it's down to wear on your spindle on the mech and the blades being new.
    I had the same issue. I've bent my arm slightly to give a better push on the screen.
  3. hades-
    9,481
    646
    the b6 and b7 screen is the same
  4. Mike_B
    Mike_B Active Member
    533
    47
    Try swapping the blades over. Depending on what you bought you may find they are handed. Mike.
  5. quattrojames
    14,050
    578
    Exactly what I did, place the middle of the arm on a block of wood, and bend the outer edges down.
    I know, but B7 arms when fitted to a B6 sometimes have this problem.
  6. andy.l
    andy.l Member
    224
    20
    Just fitted mine and a new scuttle only to have the same problem,doesnt touch the passenger side of the glass,not happy :(
  7. stuhow3361
    stuhow3361 Member
    210
    14
    Had same problem a month ago when my wipers seized.You've probably bent the mech when taking the wiper arms off the spindle.I spent ours trying to adjust this and bend the wiper arms.In the end i got p****d off and bought a new mech from Audi for £75 - problem sorted instantly.
