More turbo lag since having engine recon - 2.0tdi
Bramley Mar 7, 2013
  1. Bramley
    Bramley Member
    389
    19
    Hey,
    I have just had my engine fully reconditioned, it seems now there is quite abit more turbo lag than previously.
    I notice it more in 2nd gear, just nothing then all of a sudden kicks me in the face.
    It was never like this before.
    The turbo blow off also sounds alot quieter aswell??
    Any ideas
  2. max69vk
    max69vk Active Member
    862
    57
    Was the turbo reconditioned too?
  3. Bramley
    Bramley Member
    389
    19
    Nope, no turbo work done at all
  4. max69vk
    862
    57
    Check the turbo pipe work is fully secure at the turbo, intercooler & EGR. If the engine was rebuilt these pipes would have been moved/removed & re fitted.
  5. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    what have you had done ?
  6. Bramley
    Bramley Member
    389
    19
    Had head skimmed, valves recut and seated, block re-bored, new piston rings, new big end bearings and 1 new conrod.
  7. tdi-man
    1,783
    64
    just had mine dun as well should be back tomo .
    i had new head , rings , new bearings . full egr delette
  8. Bramley
    Bramley Member
    389
    19
    drives lovely bar the lag, it may just be when its cold tbh.
    Would this make a huge difference when cold then?? more lag??
  9. tdi-man
    1,783
    64
    um not sure just got mine back today so am running it in cant realy open it up at the moment .
    may just be a loose turbo pipe.
  10. Bramley
    Bramley Member
    389
    19
    You dont wanna go really steady when running it in, still drive it meanfully but dont go about 3kish
  11. tdi-man
    1,783
    64
    correct
