more suspension questions
egesford Feb 12, 2012
  1. egesford
    egesford Member
    346
    ive just ordered vogtland -35mm springs and dampers for my tdi 110. is there anything else worth doing at the same time?
    im putting on new top mounts and was going to buy a bush kit and change anything thats easily accessible but ive heard of people puitting different arbs on aswell. is this worth doing and does anyone have the relevant part numbers?
    thanks
  2. sportstractor
    sportstractor Chugger
    2,709
    top mounts and strut top bearings. Could rebush the wishbones if there is excessive movement. You can fit the R32 arbs on front and rear if you want to go that far, think part no.s are in the stickys somewhere.
  3. <tuffty/>
    21,897
    4,205
    If the A3 he has is a quattro...
  4. egesford
    egesford Member
    346
    fwd
  5. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    is a 35mm drop on a FWD far enough to start having issues with the driveshafts rubbing the ARBs?
  6. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
    i dropped my a3 30mm and after a few weeks after settling down the drive shaft started rubbing on the arb on full lock.
  7. Alex C
    3,297
    373
    so a new ARB then
