- Joined
- Aug 22, 2011
- Messages
- 999
- Reaction score
- 39
- Points
- 48
- Location
- https://t.me/pump_upp
- Website
- t.me
i had a strange thing going on yesteday, only noticed it in 5th but then trying in other gears 3rd/4th it was doing the same.
18psi at wot up to 5k, running vcds lite on the messuments, i get idle, pulling away gives part throttle, and then enrich as i put the throttle down past half way, even at full bost wot, the system goes in to part throttle at 5k, and the boost drops to 12psi.
is this the system protecting? read ages ago about the resistor mod between wires, so the system see say 12psi rather then the boost your running to prevent limp
so basicly doing 50/60 going wot, full boost, if i back off a little say 1/8-1/4 throttle the car seems to boost a little more and want to go more,
does this all sound mapping related. maybe its running a geniric chip. or just not set up right?
even tho its a k03 its always felt weezie, even tho full boost is 18psi between 3 and 5k. but even from the start i thought they are ment to boost longer, or cant the ko3 give 18psi past 5k?
so im going to get the car on vcds again and see if backing off throws it back to enrich,
ill try and record my screen to show what i mean
