Moisture in o/s headlight
sam4191 Aug 31, 2009
  1. sam4191
    sam4191 If In doubt, Flat out!
    417
    Hi guys.
    I washed my car on Saturday, no different to how i usually would. I went out in the evening, and noticed that the O/S headlight was fogged up on the inside. It keeps clearing and re appearing now. Any idea's on how i can clear it. I have looked, and there is no obvious way any moisture would get in! =S I have facelift headlights if this helps.
    :think:
  2. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    How are you washing you car? is it with a pressure washer? may have a small crack/hole somewhere, they are quite easy to remove to inspect further
  3. aragorn
    18,665
    880
    The lamps are actually open to atmosphere.
    Theres a little vent thing underneath, so they can fog up from time to time.
    Audi will usually tell you to sit with the main beam on for 10 mins to dry them out.
  4. rasA4
    3,287
    119
    cheers for that info aragorn, must be using a pressure washer and aimed around there?
  5. aragorn
    18,665
    880
    aye, maybe even a hose would do it.
    Ours sometimes fogs up in heavy rain.
  6. sam4191
    417
    No, I use a hose.... just chucked a bucket of water over it to rinse it this time though. lol
    Oh right... Thanks for that Aragorn... will give it a go! Will let you know the results...
  7. Geeman
    Geeman Low Life
    1,318
    Mine did the same the other week. Was really puzzled. Not done it again since.
  8. Broken Byzan
    13,244
    468
    Is that why you set fire to it, to dry the headlight out, a bit extreme, hey !!:icon_thumright:
  9. Geeman
    Geeman Low Life
    1,318
    Funny! :moa:
  10. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    When I first got stinky and she had the bosch pre facelifts they were a mess. Really dull and starting to go green. After a bit of examining I found out that the glass can come off the older unit and be cleaned. There's a rubber seal around the lens (carefull, one of mine almost broke) and lens just comes straight off. After a good clean they were excellent... This may allow you to get in and see if there's any water trapped or if the breather hole has become a bit bunged up.
  11. yendall24
    yendall24 Member
    571
    9
    i had this problem on my car so i removed the black plastic cover on the back and left it to dry out for a few days then i ran a bead of silicon sealant inside the covers seal and put it back this was 3 months ago and it as not happened since its worth a try
  12. dieselfitter251
    1,120
    Sorry, just realised you have facelift lights.... still. Not sure if the plastic lenses come off the facelift units?...
  13. aragorn
    18,665
    880
    Not without a lot of effort with heat guns, screwdrivers and pliers.
  14. sam4191
    417
    Thanks everyone!
    looks like it's not a rare problem! Shame it's not that easy then dieselfitter! and well done one the 250k by the way!
    Have sat with the full beams on for a while, a couple of times now, but not much happened. Will take it out have a look i think! lol.
  15. dieselfitter251
    1,120
    lol..
  16. neal
    neal Member
    30
    mine did this just before the mot had to take the bulb out and dry it out with a hairdryer from the back.just been careful when washing around the headlights since and been ok since.
  17. aidank1981
    aidank1981 Member
    252
    i through one of those othwise useless silicone packet things in an left it for aa few days, made sue it was a nice day when i took it out, seems ok so far touch wood...
  18. sam4191
    417
    Sounds like a plan!! lol! Lovely looking car by the way eatdegrub!
    I hairdryer'd it the other eve. Most of the moisture has not gone, could do with another 10 mins, but til we have some nice weather... twill do! lol
