Ess_Three
- Joined
- Feb 19, 2001
- Messages
- 5,383
- Reaction score
- 20
- Points
- 38
- Location
- Aberdeenshire
- Website
- www.audi-sport.net
andreitentean said:If you think that I came here wanting to argue with you, you are wrong.
I don't think you wanted to argue.
You posted something as fact and I told you it was crap.
That's all.
I am telling you about my experience and, belive me, I am not a granturismo player on playstation!
I couldn't care...I don't even own a Playstation.
The power that I told you is CORECT.
It is real life power , NOT 4500 rpm power.
And what precisely does 4500 RPM have to do with things?
My peak power was at 5250RPM. Look at the damn graph.
So what HAS 4500 got to do with it?
That's not even peak torque.
I have done at least 3 diferent turbo upgrades on my S3, excluding the fapt that I putt everything on the standad K04(silicon hoses,intake silicon hose, diferent intake filters and kits,rollers,fmic,gaskets,spark plugs,coils, diferent acuators or blowoff valves, all the N75, race exhaust and even APR downpipe) and by diferent I mean more than one!
I'm not dusputing that.
I spent 3 years getting my S3 to make those numbers and spent a fortune doing so...rubbishing many so-called upgrades in the process.
Again : you can not exceed 255-260 bhp at factory peak power rpm or higher.
Where is factory peak power?
5900 RPM isn't it?
So let me see...210 BHP @ 5900 standard against lets say 265 BHP @ 5900 - interpolating the graph as shown.
Isn't that higher?
It's on the graph.
I agree that a K04 will never give you top end as it's too small...but you can get WAY over standard power at the standard peak power point, easily.
It's all there...on the graph.
You can exceed this at lower rpm, like 4500, which is optimistic in my opinion, but this "mid range peak power" doesn't do anything good for you. You overstress the transmision and the cluch and tends to lose traction in wet,cold or winter conditions that our car is famous for.
Ahh...OK. You don't believe the figures.
That's fine.
I have 20+ dyno plots for my S3, 30+ for my GTI and several for my 911...not to mention many others all that show exactly standard power on standard cars ranging from 125 BHP (Lupo GTI) to 320 (911).
All on the same dyno...
All with the same operator.
But this set of figures is optimistic eh?
I have dyno plots from that S3 starting at 208 BHP / 199 lb-ft through every stage of the 3 year process...up to 275 BHP /332 lb-ft.
So is every dyno plot optimistic?
For every car?
Over 4 years?
As for the "mid range peak power doesn't do anything for you" I've never heard such drivel.
It gives you the grunt you want without having to rev the nuts off an engine that in standard form, doesn't rev especially well...saving wear if nothing else.
I didn't drag race the car so I'll happiliy trade some top end for lots more torque and midrange as that's what makes it quick through the gears and out of corners.
It's not as if the S3 doesn't have the traction when set up properly (as opposed to the crap standard set up)
As a side note...the S3 chassis is crap standard. Numb, lifeless...
Adding lots of midrange grunt and having a decent chassis set-up allows you to make the chassis work, make it throttle adjustable where it isn't as standard.
At 315 lb-ft @ 4000 RPM mine had total traction...by 330+ it was getting a handful and was a bit wild in the wet...but still far more involving that a standard or less aggressively modified car.
PS: try to find nicer words for my comments because if I put a picture with my garage you will see that I am not a virtual player and who is "********"
I have no interest in whether you play with cars, your playstation or your toilet parts all day long. It's irrelevant.
Your comments are uninformed and false.
Are thay nice enough words?
I'm not trying to terach you the ins and outs, or to make my car seem something mythical (it wasn't...it was a well set up and carefully modified S3. That's all) but I AM trying to prove you can get 280BHP out of a highly strung S3 (as per your original point) AND more than factory power at factory peak power.
