mmi upgrade
vw754 Mar 20, 2013
  1. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    is it worth getting the cd pack to upgrade the mmi in a 2006 q7 ? ive heard it can even eliminate battery drain,and other bug fixes?
    mine got the 4 772 i think the latest is 5570 ? any pro's, cons? component protection be affected?
  2. s8craig
    1,753
    56
    Never heard of it fixing battery drain, i think your clutching at straws there, it removes the battery monitoring from the MMI and you have to manually put it back (if you had it in the first place)
    It has some bug fixes for the bluetooth and other bits, so it is worth doing to bring things up to 5570. But be aware if it goes wrong you can feck up a module and that can be costly.
  3. vw754
    2,345
    58
    ok,thanks,can it go wrong? what happens if i dont put the battery monitoring back in?
  4. s8craig
    1,753
    56
    It's rare to go wrong, nothing happens if you don't put it back, you just get frustrated as your missing a function from the MMI.
    As you have such a high version already your not likely to lose functions that are there, it happens when you upgrade from lower rev software such as 2120.
  5. vw754
    2,345
    58
    ok,nice one,aslong as i do what instructions say,i should be ok then, my version is SW:42.2.0 0709 42.20 THEN? I THINK.
  6. s8craig
    1,753
    56
    What instructions?
  7. vw754
    2,345
    58
    IF ANY,or il just start with cd 1,2 and 3.....ive read somewhere to use cd 2 twice?,im sure it will come with instructions if i buy from audi.
  8. vw754
    2,345
    58
    if i get the 2013 sat nav cd from any audi sat nav, will it work in my q7?.........or just update mmi?
  9. s8craig
    1,753
    56
    No it doesn't come with any, the disks are for installation by technicians so no instructions are provided.
  10. vw754
    2,345
    58
    ok,is it quite simple then,just insert each disc one by one in the in-dash 6 disc changer?
  11. vw754
    2,345
    58
    ordered the 3 mmi discs from audi,how do i put the battery monitoring back ?
