MMI Navigation vs MMI Navigation plus
fwabbly Feb 17, 2014
  1. fwabbly
    fwabbly New Member
    What's the difference? Is it just that the plus package has the touch feature or does it also upgrade the screen?
  2. elan2s
    elan2s Active Member
    344
    40
    By going with Nav Plus you get a larger MMI screen and the touch pad on the central console. The navigations system also is stored on a hard disk drive rather than using an SD card and this allows 3D imaging and also images of major landmarks displayed on the MMI screen when showing the map. There is space (c10gb) on the hard disk to store music or videos and the in dash CD drive is upgraded to DVD and you can play films etc when the car is stationary. If you take the Tech Pack option rather than simply the navigation upgrade you get Audi Connect that amongst other things gives you access to Google maps and better real time traffic info. The standard navigation (and Nav Plus without Audi Connect) uses TMC data which is much less comprehensive.
    Hope that helps
    PeteBSK likes this.
  3. BahnStormer77
    BahnStormer77 BahnStormer
    2,782
    61
    mine's not got the full techpack and I still get rsap + google traffic + google earth + streetview for POI's and destinations.
    the 10Gb storage on the HDD is nearly useless, but it does free up a SD slot and the touch entry is amazing after years and years of that spinny dial / voice input!
    PeteBSK likes this.
  4. elan2s
    344
    40
    You must have specified the Mobile Phone High - With Online services option in order to get the connectivity
  5. BahnStormer77
    2,782
    61
    erm.... I guess I do - I thought the mobile phone high (and the Audi Connect) was part of the MMI Advanced (Touch) hardware, but it looks like that is another extra....
    I didn't spec the car - I bought it last year with a couple of hundred miles on the clock as an unused Audi demo car - it was the only way I could get the 3.0TFSI engine without getting an S5 Sportback (too small) or an A7 (annoyingly slightly smaller bootspace than the A6 Avant and with KILLER insurance - £1000/year more!).... what can I say, double-buggies are big!
    PeteBSK likes this.
  6. elan2s
    344
    40
    3.0TFSi no longer offered on the A6 (in the UK) so yours will be something of a rarity
  7. BahnStormer77
    2,782
    61
    Ta, I know.... but petrol residuals on larger cars are pretty poor most of the time. A pain to get it slightly off my preferred spec, but it only had 250 miles driven by other people and with around 30% off the book price was a fair compromise, just a pain that I have to pay nearly £1000 to add DAB, which is standard on most cars, but was an optional extra on the C7 S-Line at launch, despite being standard on the C6 S-Line (and most SEAT's, Fords, etc, etc)....
  8. elan2s
    344
    40
    Don't think was ever standard on the C6, unless it was part of some run out special edition. The cost of the DAB module from Kufatec (FISTUNE® DAB / DAB + Integration Audi MMI 3G / MMI 3G +-39703) for your C7 (this is the one for the 3G+ system you have) is about £300 plus fitting (they claim it is a 30 minute job!) so well under £1000. My C7 has the SD Card Navigation and for that I apparently need I need to replace the whole Navigation unit to add DAB and that is silly money, although I have just noticed that Kufatec are now offering a module for those with the RMC navigation system at £300 so maybe not all is lost. The only issue with these aftermarket options is that they do not support auto switching between DAB and FM depending on signal strength. Note you will also need the correct antenna module to connect to the antenna in the glass (rear or side depending on whether yours is saloon or Avant)
  9. BahnStormer77
    2,782
    61
    It was 100% standard on the A6 S-Lines (not standard on the SE's), I'm not sure how long that was the case, but I was watching the A6 and A7 spec's from 2010 onwards VERY closely, so those wouldn't have been run-out specials!
    If it is £300 + £75-£100 for aerials, plus another £50 for the adapters, plus several hours of skinned knuckles as potentiallly messed up interior, then I'd rather just pay the extra to get it done by Audi.
    I'm waiting for them to confirm again (I've lost the e-mail as it was sent to my old work address), but I think it was actually about £800 for the DAB and £1000 or so for DAB+DVBT.
  10. BahnStormer77
    2,782
    61
    I'm pretty sure I've seen DAB on non-touch versions of the MMI unit from Audi, have you asked Audi how much it would be to upgrade?
  11. elan2s
    344
    40
    SD card cars can have DAB as a factory fit, however on these cars the DAB module is embedded in the navigation unit rather than being an separate unit as is the case with the implementation in cars with the HDD navigation, hence the need to replace the navigation unit. The Fistune unit from kufatec looks to be a viable alternative even if it is not perfect
  12. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    So we picked up our new A6 on Tuesday which is MY14 (Identifiable due to the auto boot opener)
    Now we spec'd Tech Pack (Not Tech Park Advanced) and we got:
    + Larger Screen
    + Touch Pad
    + DAB
    + Google
    + WLAN
    + AMI
    + Bluetooth
    + Sim Card Slot
    Now Audi have released the "Official DAB Retrofit" which is literally a new Tuner module with a few cables, no instructions at all (Not like Cruise Control or towbars). We tried fitting it to an A4 but it didn't want to play ball. It also needs component protection turning off so even if it gets retrofitted, you have to visit a main dealer. I have been told and confirmed that it will work on a variety of cars but for the A6 it works on:
    A6 / S6 / RS6 (C7) Avant : 2012 - 2015
    A6 / S6 (C7) Limo: 2011 - 2015
    A6 (C7) Allroad: 2013 - 2015
    A6 (C7) Limo Hyb: 2012 - 2015
    Hope that helps!
    Tim
  13. BahnStormer77
    2,782
    61
    Tim - what's the cost on that DAB retrofit pack?!?
  14. Vladimir Kust
    Vladimir Kust New Member
    Hi
    It is posible to replace RMC MMI to MMI 3G plus?
    I see that the jacks is not the same:(
    Thank you in forward!
  15. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,043
    789
    Yes, but you need a new MMI 3GP unit, larger screen, Radio, wiring harness and AMP depending on what sound system is installed. If you can do the job yourself, then the parts can be cheep enough less the £1,000 but if you need some to do the work + make the harnesses then you will be looking at over £2,000.
  16. Vladimir Kust
    Thaks mate!
    I have the radio already, so i will looking forwad for the rest :)
  17. PeteBSK
    PeteBSK Member
    72
    Good discussion on something that I really agonised over when speccing my new A6 in 2015. I went for the Tech Pack in the end that brought MMI Plus. I loved the Google Maps, but the novelty is wearing off. I am finding that the restrictions that I am finding with rSAP are souring the overall experience - and Apple doesn't support rSAP, make sure you're acutely aware of that. Ultimately it would seem to be easier to just get a contract SIM and put that in the car for the data services and have your mobile phone connect over bluetooth for calls. When the phone (mine is a Samsung Galaxy Note) is connected via rSAP, you don't get any emails coming through on the phone- not that you could read them whilst driving (!), but also you can't use other data services on the phone like Spotify as there's effectively no data connection on the phone as the car has nabbed it. The only way around is to use offline music (e.g. I use Audible) _or_ disconnect the phone from full rSAP and reconnect only has hands-free - then you lose Google Maps/Traffic/Petrol prices etc... etc. it's good, but Audi has some work to do to bring this up to what current tech is actually capable of. If I was buying now, I might spec it only to improve the re-sale desirability of the car rather than as an out and out must-have.
  18. DaveW
    DaveW Active Member
    334
    57
    I have the tech pack on my 2015 A6 and do get emails on my galaxy S5. You are correct in saying the car 'nabs' the data connection, but you then need to connect your phone to the car by wifi to get it back again. That way you get full RSAP data connection along with phone data, for the likes of the MMI connect phone app, which allows online music streaming via Internet radio or Napster/Aupeo.
    Cheers,
    Dave
    PeteBSK likes this.
  19. PeteBSK
    PeteBSK Member
    72
    Oooooooooohhhhhhhhhh!!!! I hadn't thought of that!!! THANK YOU @DaveW ! Will try that today!
    DaveW likes this.
  20. DaveW
    DaveW Active Member
    334
    57
    No problem.
    Have you noticed recently that most of the filling stations have disappeared from Audi connect fuel prices? It was listing 3 in my area, the nearest one as 12 miles away when there are plenty nearby.
