MMI cables
poweller Nov 26, 2012
  1. number3
    number3 Active Member
    335
    27
    Phone is paired, but bluethooth was off I think! Ill have another go with it tomorrow !
    mark.
  2. stevependleton
    stevependleton New Member
    14
    I too can tell a difference between the sound from my iPhone 5 and an SD card but I believe that's down to the fact I reduce the bit rate when transferring music to the phone to save space.
    I have now decided to reduce the number of tracks on my iPhone, keeping them at the original bit rate and use a couple of SD cards for the rest of my music (I don't have the sat nav option so can load both slots).
    Steve
  3. number3
    335
    27
    gotta say i trust in the Vertigo , but tried again and still convinced i could hear a difference with the Songs being played via an SD card. probably just in my head!!! lol, anyway im stuffed again as i changed to a iphone 5 over christmas so back to square one again lol.
    Mark
  4. suzannec
    suzannec Member
    117
    9
    I finally got my red cable. Yes it took that long. Anyway slightly annoyed as my Ipod Classic 80gb isn't compatible! :-(
  5. Vertigo1
    Vertigo1 Well-Known Member
    3,465
    625
    We had that problem when Dave came to listen to my B&O and tried his iPod Classic and it wouldn't work (his might even have been an iPod Video). Sorry, if I'd realised you were going to pair an iPod Classic with it then I'd have mentioned something sooner.
    suzannec likes this.
  6. selar
    selar Member
    161
    22
    What about those of us running Android? I streamed my spotify library over Bluetooth when I test drove but I don't remember whether the artwork came across and I didn't have time to play around with using the car's controls to pause etc. Anyone know anything about how compatible non-iOS devices are, wired or otherwise?
    P.S. I haven't ordered the Tech Pack.
  7. deci
    deci Active Member
    308
    125
    43
    One reason for a difference in sound from the SD and ipod could be the ipod software settings eg. soundcheck/compressed audio settings, EQ settings etc. Generally I set my ipod to 'flat' EQ as a rule and don't use any 'soundcheck' functions.The SD card's mp3s will be read as-are by the MMI system.
  8. Ben (T25) Ruz
    Ben (T25) Ruz Audi Virgin
    Two dumb audio questions (as my first audi has not arrived yet):
    1. Does red/blue cable charge iphone?
    2. Is there a max size of SD if I go that option?
    Ben (only a few weeks to wait now)
  9. Vertigo1
    3,465
    625
    1. Yes
    2. 64GB
  10. PjDali
    PjDali Member
    169
    14
    On a similar note
    Should the dealer supply either blue or red cable upon delivery if the car or should I be asking to purchase one at pick up time?
    If so should I specify blue or red? I don't have the Tech Pack but will be using an iPod and iPhone for music as well as SD Card.
  11. Ben (T25) Ruz
    Thanks Vertigo1. PjDali, not sure but presumed the cable was a seperate purchase accessory...happy if it's not! (I don't have the tech pack ordered either).
  12. faisal_16
    faisal_16 Member
    84
    19
    I've been told by dealer that a USB and iPod cable will be supplied with the car.
    Are the red collar cables standard issue now or should I specify this before delivery?
  13. squiretolley
    squiretolley Active Member
    458
    118
    43
    The brochure says that the standard MMI supports up to 2TB SDXC cards. I know anything above a 64gb card can be very expensive, but it looks as though you could go larger than 64gb (SDXC only!!)
  14. Pganders
    Pganders Member
    49
  15. mack71
    mack71 New Member
    21
    Audi AG charge the dealer for the cable, the dealer charges you, I think £65 inclusive of vat. You can ask them to take it off the order or not take it when the car is delivered. Get them on eBay for £10.
  16. squiretolley
    458
    118
    43
    So will the Apple cable charge an iPhone, regardless of tech pack etc?
  17. mack71
    mack71 New Member
    21
    Yes, it's basically Audi's system to connect Apple devices to their MMI. USB cable does the same.
  18. XXXCorps
    XXXCorps Member
    194
    27
    This red and blue cable thing was prevalent when I had my Audi A1 S Line back in 2011 with no cars showing album artwork on the MMI when connecting an iPod. Audi rectified this later that the year by updating the hardware and supplying red cables. Unfortunately they were not backward compatible so if you had an earlier vehicle you basically screwed. I seem to recall there was a way to increase the volume coming through the MMI cable in the radio settings...
    Anyhow someone try a recent iPod derivative through a red cable on the basic A3 setup and let us know the result. My 8V A3 order tomorrow may hang on this.
    PS. I got the cables free with my A1 so nobody should be paying for them!
  19. Vertigo1
    3,465
    625
    It's strange that the brochure mentions 2TB because the user manual says 64GB. God knows what the right answer is. In reality, it supports SDXC so will probably work with any size of card, they just state what the maximum size they've actually tested it at is, so even assuming they only tested up to 64GB when they wrote the manual, I'd still expect it to take larger cards in reality. I wouldn't be surprised to find 2TB cards worked but I'd also not be surprised if it was rather slow with that much data to search through.
  20. selar
    selar Member
    161
    22
    Just following this up since no-one has replied yet - any Android users had a go yet? Particularly with Spotify? :)
  21. Zig
    Zig Member
    81
    Is the correct cable part number 4F0051510R identified as adaptor for iPod and iPhone?
    If so do these tend to come with the vehicle or do you need to buy them?
  22. XXXCorps
    XXXCorps Member
    194
    27
    They should come free with the vehicle; if yours doesn't then ask the question; why not? I noticed on 2 separate occasions with 2 separate dealerships that they conveniently ended up in the salesman's drawer!! Also they should be able to supply the red cable gratis if asked.
  23. leof
    leof New Member
    22
    Hello
    I am new to this forum having just taken delivery of my A3 SE, I have just sorted out the question of cables after a bit of research. My A3 came with a red grommet cable which did not work with my (getting on a bit) Ipod 80g classic, I have just picked up the cable with a blue grommet and it worked straight away.
    Here is a list I found on another site which lists all versions of Ipod/Iphone the version is I believe the firmware on the Ipod/Iphone.
    I hope this helps and I am sorry if this is mentioned elsewhere on the forum.
    There are two versions of the iPod cable that can be used.
    - 4F0 051 510 K (with blue marking) without Video function
    iPod mini (From Version 1.3.0)
    iPod nano
    iPod 4G (From Version 1.2.1), iPod 5G Video, iPod 6G classic
    iPod touch
    iPhone
    iPad (From Version 4.2.1)
    - 4F0 051 510 R (with red marking) with Video function
    iPod nano 5G (From Version 1.0.2)
    iPod touch 1G, 2G, 3G and 4G (From Version 3.0.0)
    iPhone 1G, 3G, 3GS and 4G (From Version 3.0.0)
    Thanks number3 I too noticed the low hum from the speakers and will have to go to the dealer to get the software update.
  24. Jenks108
    Jenks108 Member
    43
    edit ' now to try and see if I can get photos to show from my contacts !!!
    Did you ever get manage this?
    edit: Sorry, trying to work out how to quote!
  25. Jenks108
    Jenks108 Member
    43
    Did you get the photo's sorted on the contacts? How?
  26. number3
    335
    27
    Nope :( tried everything , could never get it to work! That's assuming that the little grey box is there to show a picture
  27. blt7878
    blt7878 New Member
    I confirm that there is a real quality gap between the bluetooth and MMI cable connection. It is very easy to test it :
    1. first, pair you iPhone with Bluetooth,
    2. then listen to you iPhone connected with the MMI cable (got the red one)
    3. at any moment switch to Bluetooth in the media source menu. The music will resume at the very same music part.
    You will clearly perceive that you lost treble and bass.
  28. Nardies
    Nardies Member
    70
    It does work, but only on a small subset of phones, i.e Blackberries, Nokia and some Samsung handsets.
    On the SD Card vs iPhone quality isn't it true that any output goes via the iPhone DAC, whereas with the SD card, it's all directly through the DAC on the car?
  29. Dylock
    Dylock Active Member
    269
    71
    Does anyone have any idea when the iPhone 5 cable is going to be released?
    If I just use the adapter do I still get full functions?
  30. DavieG87
    DavieG87 New Member
    24
    9
    Im using the red cable with a 30 pin to lightning adapter on my iphone 5 and everything works fine
  31. Dylock
    269
    71
    Ah that's ok then, I thought there was some features missing. Ill do that, cheers for the reply :)
  32. Gswearengin
    Gswearengin New Member
    17
    9
    Is album art supposed to work with both the SD navi and the tech pack? I was sort of under the impression that was one of the features you got for spending €1100 for the upgrade, but I would love to be wrong! I'm a bit OCD and think the album art thing is a great feature.
    Also, does anyone know whether it is possible to connect one iPhone via the MMI cable for music and another via Bluetooth for everything else, or will that make the system explode? My plan is to leave my old iPhone in the car and use it just for music. I will have to wait and see if it is a better idea to just use an SD card. It would be fantastic to have my whole library (150 Gb or so) accessible!
    Thanks,
    GS
  33. hittchy
    hittchy Active Member
    557
    74
    Album art does work on the standard set-up. You don't need the Tech Pack.
    Can't see a problem having two iPhones connected. I often have my iPhone connected via Bluetooth for calls and music plus my iPad 3G connected for music via the cable. All will work fine and are selectable through the MMI.
  34. 97catalunya
    97catalunya Active Member
    546
    161
    43
    Wow where do you manage to fit the iPad? Lol
  35. hittchy
    557
    74
    I specced the Audi Phone Box Tardis Edition. As soon as I plug it in, the iPad seems to shrink down to iPod size and fits perfectly in the armrest. It's option code DRW on the Audi Configurator, although I'm not sure it's still available. ;)
    On a more serious note, it's a mini - just thrown onto the passenger seat. To be honest, I've only really used it in the car when I had new Spotify music on it which I couldn't be bothered to transfer onto my iPhone.
  36. 97catalunya
    546
    161
    43
    He he now that would be a handy option ;)
  37. Raul_sbd
    Raul_sbd Active Member TFSI Owners Group Team Scuba Audi A3 S-line owners group Manual
    251
    169
    43
    I bought the cable with the red collar and I have the 1rst gen iPod touch with 3.01 firmware. It just says loading when I plug to Ami.. any ideas?
  38. TimWills28
    TimWills28 Well-Known Member Team Floret Silver VCDS Map User Audi A3 S-line owners group TDi
    1,213
    667
  39. Karen O'
    Karen O' Well-Known Member Team Glacier Audi A3 S-line owners group TDi
    480
    694
    93
    Was the dealer supposed to supply me with a cable? And also was i supposed to ger a sim card too ?
  40. Gordo77
    Gordo77 Well-Known Member Team Navarra Audi S3 Manual
    1,192
    2,286
    Don't think you get a USB cable... have you got the tech pack? It will have an embedded SIM card, fitted at factory I think.
