MMI cables
poweller Nov 26, 2012
  1. poweller
    poweller Member
    74
    I think I have discovered why my Mmi system isn't showing album artwork, the dealer has supplied a cable with a blue grommet which I believe is the old mmi cable. For album art and video to work I believe you need a cable with a red grommet. Please can a new a3 owner with a fully functioning mmi system check that their cable has a red grommet? Do I have any grounds to ask the dealer to supply the latest mmi cable!?
  2. Vertigo1
    Vertigo1 Well-Known Member
    3,661
    743
    I'll have a look when I go out to the car later. (Still have slippers on atm :p)
  3. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    True - you should have the red one for album art.
    You should've been supplied the correct lead, go back and get it off them ;)
  4. Vertigo1
    3,661
    743
    Yep, red grommet here.
  5. poweller
    poweller Member
    74
    thanks, they have said they will replace it but I have to send the blue one back first! Apparently it is their policy to issue the blue one as standard.
  6. Spurrellian
    Spurrellian Member Team Cosmic Blue TFSI Owners Group Audi A3
    94
    37
    Also fyi I have had a look on the audi compatability website and only a few Apple devices will display album art. A nano 4g doesnt which i'm quite surprised at!
  7. Spurrellian
    94
    37
    poweller likes this.
  8. Vertigo1
    3,661
    743
    Useful link, thanks for that!
  9. Audi Man Dan
    Audi Man Dan Member
    55
    9
    Same artwork problem here Vertigo, let me know how you get on exchanging the lead.
  10. daveb99
    daveb99 Member
    119
  11. Vertigo1
    3,661
    743
    I think you're confusing me with someone else - I've got the newer cable with the red grommet and have no problems with artwork from my iPod Touch.
  12. peterw47
    peterw47 Member
    85
    12
    Are we talking about with the standard mmi or with tech pack? I've been supplied with blue grommet!
  13. poweller
    poweller Member
    74
    Mine is standard, hoping that the red grommet cable will solve the artwork issue.
  14. number3
    number3 Active Member
    335
    27
    Was also supplied with the blue cable, which doesn't show the art work, have emailed dealer and asked for the red, will see what they say!
    what I did note was that some of the same albums copied onto a SD card worked, album art was showing, but not on all, which when I read through the manual may be down to the size of the pic, I believe it has to be 500px by 500px or under , anything over wont show.
  15. stevependleton
    stevependleton New Member
    14
    I was supplied the blue cable too, I didn't know any different at the time I picked the car up, but as I have an iPhone 5 with the new Lightning port I can't see any point in hassling my dealer for the red cable.
    I've been using Apple's Lightning to 30 pin connector which works but obviously no album artwork.
    It bugs me because all my music has the artwork embedded and the display doesn't look so nice with the grey square and a question mark on it!
    I can't see any new cable from Audi with the Lightning connector solving the issue though as I assume the 500 pixel limit is a limitation of the system itself rather than the cable.
    For now I've loaded up an SD card with music and use that, most tracks display the artwork except of course those where the image is too big. I don't fancy going through all my albums and re-sizing the artwork and I've not found any software that would do it automatically either so I suppose I'm just going to have to live with it.
    I love the car though, which is my first Audi after 35 years of driving!
    Cheers,
    Steve
  16. number3
    335
    27
    I downloaded some freeware last night which had an auto correct option , on the few i corrected it seemed to fix the album art, but im not convinced there wasnt another issue it fixed which then allowed the artwork to be shown.
    Ill have another muck around with it tonight and if its anygood and allows you to autocorrect the size of the artwork, ill post a link.
    As im with you on that point, not wanting to spend time correcting something that shows fine on all my apple hardware.
  17. stevependleton
    14
    Sounds promising, what's the software called, I'll have a play myself
  18. number3
    335
    27
    ill tell you once home as I can't remember !
  19. Vertigo1
    3,661
    743
    All this blue/red business is bizarre. I can't fathom why there are two different versions of the cable or why they'd supply different ones to different people.
    Perhaps you're supposed to get the blue cable unless you have the Tech Pack, then you get the red one? Just a thought.
  20. suzannec
    suzannec Member
    118
    10
  21. number3
    335
    27
    that's it, but around one of the ends where the cable meets the connector there is either a red or blue ring inlay.
    Mark
  22. number3
    335
    27
    am using two now to see which is the best.
    MediaMonkey & Jaikos
  23. suzannec
    suzannec Member
    118
    10
    Thanks number3, hopefully my cable will arrive tomorrow/Monday so I'll be looking closely as the dealer said it was all black and didn't know what I was talking about! LOL
  24. stevependleton
    14
    Thanks number3, downloading now and I'll give them a try this weekend
  25. number3
    335
    27
    Jaikos seem more user friendly !! well will see once i plug the sd card back in to see if its fixed the artwork lol
  26. number3
    335
    27
    Jaikos fixed my art problem!! You can upload artwork onto multiple files and check its the right size. Very easy programme to use!
    mark
    edit ' now to try and see if I can get photos to show from my contacts !!!
  27. stevependleton
    14
    Hi Mark,
    Yes I agree that Jaikoz is the better app and I quickly sorted through the 20GB of data I'd loaded to an SD card. So far all album artwork is showing quite nicely on screen.
    Cheers,
    Steve
  28. Vertigo1
    3,661
    743
    For anyone using iTunes, I've found the TuneUp Media plugin/addon very useful for finding missing artwork. It also has a system for identifying and correctly tagging tracks and will "listen" to music to identify it via an online database, much like Shazam does. You can literally feed it files like Track01.mp3, Track02.mp3 etc with no ID3 tags at all and most of the time it will identify it correctly and tag it all up for you :)
  29. Spurrellian
    94
    37
    For anyone that is interested i found out Audi are developing iphone 5 cables with apple
    suzannec likes this.
  30. Vertigo1
    3,661
    743
    Interesting - suggests it doesn't work properly with the available adapters, although I've not seen any actual evidence either way.
  31. stevependleton
    14
    I have a "blue" cable, adapter and iPhone 5 which all seem to work just fine apart from no album art showing on screen, however the A3 is my first Audi so I've nothing to compare it against.
  32. johnhugh
    johnhugh New Member
    9
    The same here, but I phoned the dealership this morning, and are sending the red cable in the post today!
  33. suzannec
    suzannec Member
    118
    10
    I have educated my dealer and they also sending me the red one!
  34. number3
    335
    27
    nothing like a good educating!!! lol
  35. number3
    335
    27
    I finially got my updated cable, and I gotta say wished I hadn't bothered !!! The sound quality is pants compared to the SD card I've been using, really noticably so!!! Will be using this for charging only.
    recomend everyone invest in an SD card for there music !!!!
    Mark.
  36. Vertigo1
    3,661
    743
    You on about using an iPod? Not had any problems at all with mine and the quality is fine.
  37. number3
    335
    27
    Sorry yes with an iPhone 4S connected, have you tried an SD card yet with music loaded, I really can notice the difference!
    Vertigo you've got the tech pack haven't you? Have you tried coping music onto the HHD yet?
    Mark
  38. Vertigo1
    3,661
    743
    I've tried an SD card briefly but the quality is no different to my iPod. All my music on the iPod is at a good bitrate and the quality is superb to be honest. If you can tell the quality is substandard then something is wrong.
    I do have the tech pack but haven't tried copying anything to the hard drive. There's only 10GB of user space on there anyway, whereas my iPod is 32GB.
  39. number3
    335
    27
    I wonder if I didn't have it fully plugged in!! Lol , as I really could tell the difference . !
    mark.
  40. Vertigo1
    3,661
    743
    You sure this was via the cable and not over Bluetooth or something? Have you previously paired your phone with the car for music playback?
    I've heard the Bluetooth connection is really poor quality due to the massive compression used. The wired connection should be fine and the only limiting factor on quality should be that of the original music file, whether on an SD card or via an iPod.
