Mk4 R32 Coilovers on S3
Jimcaws Apr 9, 2014
  1. Jimcaws
    Jimcaws New Member
    Hi there,
    I know this has been covered and i did find a thread stating they would fit but the spring rates are different, However i am currently in discussion over a set.
    Will i notice any difference with spring rates etc ?? They are AP's by the way
    Thanks in advance,
    Jim
  2. JimS3
    JimS3 Active Member
    736
    72
    r32 has over 100KG extra weight up front, quite a difference.
  3. Jimcaws
    Jimcaws New Member
    Thankyou for this,
    However how much will that effect fitment and what will i notice ?
  4. JimS3
    JimS3 Active Member
    736
    72
    They will physically fit. However by stiffening up the front more than the back I suspect you will increase understeer and have a less forgiving ride.
    Usually you want the back stiffer than the front for better turn in and to dial out understeer.
    Prawn likes this.
  5. Sam_
    Sam_ Down under
    3,038
    480
    It wouldn't surprise me if the budget brands don't differentiate between the Mk4 cars (TT/R32/S3)...
  6. daz-20vt
    daz-20vt Well-Known Member
    2,836
    584
    Ive looked at a few options and the spring rates are different from s3 to r32.
    Surely if the r32 is heavier up front it will be stiffer up front?
    And sureluly the manufactuer would have made the model specific parts as best they could? Why make specifically for s3 if the r32 ones are better?
    Ap s3 coilover spring weights
    Front upto 1040kg
    Rear upto 1050kg
    R32
    Front upto 1110kg
    Rear upto 1060 kg
  7. Prawn
    11,608
    3,583
    as per what Jim and Daz have said, R32 will be a higher spring rate up front to support the cast iron boat anchor fitted to the R32.
    Stiffer front will give increased understeer and less ride compliance.
    Airs likes this.
  8. daz-20vt
    2,836
    584
    This is one of the places you dont want to get wrong mate. They would need the extra weight to work the spring and you wont have it. Id imagine it would be crashy and coilovers arent exactly smooth at the best of times.
    Do it right do it once!!
    Oh how i wish i used my own advice!!
  9. Jimcaws
    Jimcaws New Member
    Brill they are the replies i wanted, Cheers chaps !
    It's not that i was trying to do anything better or different they had just come up at a decent price second hand so thought why can't they lol !
    Back to the drawing board for me then ;) thanks again
  10. daz-20vt
    2,836
    584
    Its annoying i know. Who knows they might work ok. But why be the guinea pig.
    Its far to costly to do twice
  11. Gary_808
    Gary_808 Member
    166
    If they're cheap enough it's worth a punt,
    New springs for coilovers are cheap as chips irc 25quid a corner when I had mine on the old track car.
    Personally I like a harder back end to, use to run 350lb fronts and 500lb rears.
    Not got round to even thinking about the s3's setup just yet.
  12. Sam_
    Sam_ Down under
    3,038
    480
    That'd be comfortable. I've got the H&R RSS which are said to be 950lb front and 1150lb rear. It's a stiff ride heh
  13. Airs
    Airs Active Member
    144
    81
    yeah i looked at this when i bought my setup, so just bought the correct ones, but deciding to sell them now as i got a great price on an level air setup, so i need to shift my BC's if your interested mate, you have a PM :) or any1 else for that matter lol
  14. Gary_808
    Gary_808 Member
    166
    That's abit extreme lol!
    But the car did only weigh in at 725kg so was a hard ride.
  15. Prawn
    11,608
    3,583
    Sams Lard **** S3 probably weighs near on 1500kg, so that figures :laugh:
    Sam_ likes this.
  16. Sam_
    Sam_ Down under
    3,038
    480
    haha! Yeah and I don't help matters weight wise :(
    The H&R RSS are known to not be the best on their own but are up there with the V3's for track work. They've got nicely matched dampers to the spring rate. I'd still rather have the V3s on a road car but these came up at a great price from a guy breaking a TT.
