MK2 RNSE CD & AMI?
Steve_B Sep 16, 2013
  1. Steve_B
    Steve_B Member
    39
    From much searching/reading it is suggested it is possible to have CD or AMI with the MK2 but not both together due to pin duplication? - I currently have a CD changer, when I go into media it shows the 6 CD's + initialising AMI which would suggest it is possible to have both?
    I guess I could try but not had the time - will any other format (other than MP3) play from the SD cards? ALAC, FLAC etc?
    many thanks
    -Steve
  2. NHN
    29,593
    1,782
    No, what the issue is, the ami goes in the socket where the changer would, cd & ami do not use the same wires.
  3. s8craig
    1,756
    56
    I've done it to two RS6 cars with RNS-E MK2, used the 6 CD changer in the boot and fitted an AMI into the glovebox.
  4. Steve_B
    Steve_B Member
    39
    Apols for the delay... very many thanks...
    Will an 8T0-305-785A CAN AMI work with an RNSE-MK2? read a long US thread on AMI, the 8TO is mentioned though lost track in all the posts what worked and what didnt...
    I am guessing it is the same as the 8P0 just from another model?
    All the best
    -Steve
  5. NHN
    29,593
    1,782
    The 8T0 ami will not work with an rns-e.
  6. Steve_B
    Steve_B Member
    39
    Perfect, thank you.
    Such similar part nos...
  7. NHN
    29,593
    1,782
    Yeah identical looking aswell :)
  8. Quattro mad
    Quattro mad New Member
    Please Clarify.
    1. I am going to replace my RNSe mk1 with a RNS-e Mk 2 in my 2003 A4 B6. Is it a straight swap regarding the wiring & coding.
    2. I want retain my cd changer & add an AMI using the retrokit designed for the RNS-e Mk 2. I understand from an earlier post that both the CD & AMI use the same connection on the RNS-e Mk2 but different pins. What is the best way to overcome this & does it involve purchasing an additional wiring harness?
    3. Once fitted, does the AMI need to be coded?
    4. Finally, I have modified the microphone wiring so it is routed via the RNS-e with my existing RNS-e, ready for SDS. With the RNS-e mk2 installed will the SDS automatically work or does the firmware need to be loaded as with the RNS-e Mk1.
    Answers Much Appreciated
  9. NHN
    29,593
    1,782
    You need specifically a mk2 SDS unit, its not like the mk1 where its a hack as such.
    We supply/fit all these systems if interested :)
  10. RustyBucket
    RustyBucket Active Member
    347
    75
    I've just carried out the mk 2 upgrade so can help with some of your questions.
    Mk 2 is a straight swap but you need to move the Bose pin. Can't remember from which to which but a quick lookup on here will make that clear. I can't help on your AMI questions but you will need to modify the firmware. Unless it already has the SDS hack version from the seller (version 220) you will need to set the downgrade option via VCDS which you can find here (http://m.vagoc.co.uk/vb/showthread.php?t=151&showall=1) then downgrade firmware to 150 and then upgrade to 220. I've almost got it all working but I'm stumpped by the mic rewire http://www.audi-sport.net/xf/threads/help-how-to-wire-mic-for-rnse-again-sorry.228150/ so if you can offer any help on that i'd really appreciate it :)
