Mk1 tt spluttering under load (1.8t 225bhp)
Jackhop22 Jun 11, 2013
  1. Jackhop22
    Jackhop22 Member
    32
    Hi!
    got some issues with my girlfriends tt, it has a bad splutter under load/boost, at its worst in third gear about 3000rpm which at times makes the eml light flash. I've plugged in vcds and it just came up with random multiple misfire. It had new plugs about 5k ago. Wired thing is, it's smooth on idle and drives well when not booting it!
    Was just curious if there was a common fault that may cause this?
    i was thinking coils, but would have thought that would be a constant misfire on idle ect
    or maybe a maf? But would have thought that would flag a fault in the memory?
    only other thing there was an old fault that cleared and didn't come back, relating to the inlet cam sensor.
    cheers for any help given!
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    i would run it and see if missfire fault reappears
    if it does then do coil packs
  3. koruptc5
    koruptc5 Member
    86
  4. koruptc5
    koruptc5 Member
    86
    \Just to add i had EXACT problem with my 1.8T after a remap, Idle was smooth, gentle throttle and light load was smooth....then bang misfires under boost with light flashing wild, eventually got so bad the light stayed on permanently...changed packs and all was good again;)
  5. Jackhop22
    Jackhop22 Member
    32
    Brill cheers for the help! Will get the coils changed after reading this, will post when I've done it! :)
  6. Jackhop22
    Jackhop22 Member
    32
    Booked in at audi for ignition coil recall! Wahooo
  7. koruptc5
    koruptc5 Member
    86
    Result:)
  8. NHN
    29,284
    1,695
    Yeap recall would be my 1st suggestion, result :)
  9. Jackhop22
    Jackhop22 Member
    32
    picked up the tt yesterday, gutted! turns out only one of the coils are originals so only got one replaced! :/ ... and the misfire under load fault still remains!, looks like i will have to get the wallet out now!
