Mk1 s3 temperature
jay1 Oct 7, 2012
  1. jay1
    jay1 Member
    168
    I have recently bought a audi mk1 s3 it's been well looked after and has a full service history and when warmed up it sits nicely
    at. 90 degrees and when I'm driving along it drops to 80 but now it's got a bit colder I was driving today at 60-70 ish in 6th gear around 2000 rpm and it was around 5degrees outside and the temp dropped to 60 is this normal?as I also have a mk1 Audi a3 1.8tand that sits at 90 constantly when warm
  2. Dani_B19
    9,113
    346
    Nope, should always be a solid 90 no matter what. Its either the cts or thermostat. The cts is the easiest to change bit the dearest, try that, if not then its the thermostat.
  3. jay1
    jay1 Member
    168
    Thanks for that what is a cts? I'm new to all this
  4. Dani_B19
    9,113
    346
    Coolant temp sensor mate, its between the block and the battery in the plastic housing that feeds the block coolant.
  5. jay1
    jay1 Member
    168
    Ok cheers mate
  6. GhazS3
    GhazS3 New Member
    12
    Yeah, i had the same issue, i changed the Coolant temperature sensor and sorted it!
    1 month later and it started to overheat, ended up being my water pump! Hope you have better luck with temperatures than i did!
  7. jay1
    jay1 Member
    168
    I hope so too!! It just had Cam belt and water pump before I bought it so should be ok thanks for the help
  8. JNP
    JNP Member
    102
    Sorry to hijack the thread jay.
    Dani, is it not normal for the temp to be at 80 deg while your going down the motorway? Mine sits there until i slow down and then goes to 90?
    Sensor fault?
  9. s3mad_dude
    s3mad_dude Noggies ruuuule!
    602
    79
    Nope. Should always be a rock steady 90. Whether you are hooning it or sat in traffic.
  10. Dani_B19
    9,113
    346
    Nope, as said, should always be at 90 mate.
  11. JNP
    JNP Member
    102
  12. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Try using the climate panel to display the reading, see if it differs from the gauge.
    If it gets up to temp when sat in traffic and does sit at 90 I would suggest it is the stat rather than the sensor, they have a habit of going every couple of years.
    Mine is on the blink at the moment, not a difficult fix either way.
  13. JNP
    JNP Member
    102
    Thanks 16Klappe, that is exactly what's happening so I ordered a new stat off Euro car parts and the gasket and will change it on Saturday.
    Hopefully will fix it :)
