Mixing Engine Oils
imported_Strider81 Jun 5, 2005
  1. Half way up the M1 my oil light went on (my fault should have checked b4 i left) so i stopped at the nearest and most dearest service station only to find they had one type of oil.
    rather than risk it i poured a little of this Castrol GTX Magnatec in to keep the ess happy- however I know this is not the optimum oil and so will it be harmfull in anyway to top it up fully with the recomended 503.01 spec?
    thanks
  2. Guest
    I am no expert in oil and i am sure someone is but i very much doubt you will have caused any problem by putting some GTX in. More problems would have arisen had you not put anything in!
  3. imported_gek
    imported_gek Guest
    Up to 1/2 a litre of a substitute oil is ok in emergencies I think.
  4. Yep, gek is spot on. I had the same thing happen on the M6 and I phoned Audi Roadside Assistance who said up to half a litre of any synthetic oil was OK in emergencies.
    Not sure what the code is for the proper stuff, but I know Mobil 1 is it!
  5. nice one guys
  6. WilkoS5
    WilkoS5 Member
    165
    I have done this the other way around. I have SLX in the engine and have topped up with Mobil1 as you say they are both 503 01.
    I think that it's OK?
  7. CJ A4
    CJ A4 Active Member
    2,664
    I hope its ok i too had mobil1 and Halfords never had any ...so had to go with the SLX longlife II seems to be ok though.
  8. PaulJC84
    PaulJC84 Owner
    2,914
    17
    Yeah i should be fine its normally only a problem if you mix semi synthetic and fully synthetic.
  9. asifgillani
    asifgillani Member
    59
    thanks for the responses - i'll top up tonight!
  10. dpeilow
    dpeilow Member
    95
    [ QUOTE ]
    [/ QUOTE ]
    Don't think you should be using SLX longlife II in the S3...
  11. neil.c
    neil.c Senior
    567
    Any oil is better than no oil, if the light comes on then you are not that far away from engine faliure, best to keep the levels topped up.
  12. dummi
    dummi smoking a6
    1,210
    as soupie says don't mix semi with full synthetic, you will get away with it
  13. imported_oilman
    imported_oilman Guest
    VW 503.01 is the code.
    SLX carries this not SLX II.
    Others are Mobil1 0w-40, Castrol RS 0w-40, Fuchs Titan Supersyn SL 0w-30 and Motul 8100 0w-40.
    Simon
  14. god_thats_quick
    2,507
    Hi Simon,
    Guessing your the same company that posts on Pistonheads - great advise by the way!
    How much is the Motul 8100 0w-40 in say 5Litre quantities?
    Cheers,
    Ben.
