Mitsubishi evo 9 intercooler into S3, possible?
Chlippo Aug 8, 2013
  1. Chlippo
    Chlippo Member
    679
    15
    I have a used mitsubishi evo 9 intercooler laying around that I was thinking giving it a go to my S3.
    Plan is to keep the fogs and grills, not loosing those.
    The intercooler looks like this:
    Mitsubishi Evolution 8 9 Stock Intercooler EVO VIII IX | eBay
    the size is:
    The core size is 19" x 11.5" x 2.75"
    Overall dimensions are:
    24.5"x11.5"x2.75"
    Note that my car is LHD.
    Planning on using 2" or 2.5" piping
    What do you think?
    PS: I have read every page in the fmic section, I know about pretty much all of them, but since I have the evo one ready, might go with that.
    Also have another intercooler that is 28"x7"x2.5" but i guess it won't fit since 28" is like 4" more than wellycooler.
  2. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    Any intercooler will fit,as for the dogs,it depends on the pipework I guess.I'd do it if I were you.
  3. MexxT
    MexxT Member
    31
  4. Chlippo
    Chlippo Member
    679
    15
    I will probably do it. the only thing that would make me change my mind is the necessity of removing the fogs, or having a messy pipe-work. Ideally I would go AHfab, but the price + shipping to me would be enormous VS fitting the evo intercooler.
    Also 2" piping doesnt seem to be a valuable option around here...but I do have pretty much all the pipes i need in 2" (which is 51 mm).
    The end goal is a hybrid turbo (aiming 330 bhp), so I want to do the intercooler setup once and for all accordingly
  5. Andrew@A.L.D
    3,879
    617
    The evo cooler is good and will fit with a little work but A RB26 Skyline cooler is bigger and better intercooler that could also be used
  6. Paradox1
    1,833
    88
    I think 63mm pipes hoses would work better than 51mm.
  7. badger5
    9,599
    2,060
    dont use 51mm - utterly pointless going SMALLER than stock dont ya think?
    60 or 63mm is advised
  8. Chlippo
    Chlippo Member
    679
    15
    You are right, smaller than stock makes no sens. I was thinking, smaller pipes, larger intercooler = maybe better results over the stock twin-intercooler. But I will get another pipe set, do it once for all.
    Bill once you see my iat's, you will understand the urge lol
  9. Chlippo
    Chlippo Member
    679
    15
    Starting:
    [​IMG][/url]
    [​IMG][/url]
    [​IMG][/url]
    Note that the Mitsubishi evo 9 intercooler is very light and supposed to be more effective since its made from aluminum.
    Will be working on this slowly, but I hope it will solve my low reading maf problem. Car pressured for leaks and got none, swapped with a used maf and got the same reading so I assume the maf is fine. I do have a new maf sensor to try on the way, as i have promised in another thread.
    My iat's are sky high, I think Scullies had similar prob with iat's and ended up getting the car back to stock (before he started his big turbo)
    Scullies, Andrew@A.L.D and Jason.s like this.
  10. MexxT
    MexxT Member
    31
    i used 51mm piping to the intercooler.
    After the cooler it was 63mm.
    made 320hp and 435Nm with a k03 hybrid.
  11. Dani_B19
    9,381
    403
    So a ko3 made 320hp, whats that in bhp because theirs no way on this earth a ko3 turbo would make that bhp let alone a ko3s.
    m19lte and G60DAN like this.
  12. Sam_
    Sam_ Down under
    3,038
    480
    GT28 with a k03 label
  13. Scullies
    Scullies Well-Known Member
    1,543
    658
    [​IMG][​IMG][​IMG][​IMG]
  14. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    Note that most intercoolers are made from aluminium and therefore light lol, you said that as though the evo cooler is different to others
  15. badger5
    9,599
    2,060
    lol
    what do you think intercoolers are made from??
    aluminium dude..
    Oe with plastic ends most often..
    aftermarket are ally
    looks like its a decent pipe outlet similar to when I mod the toyo core for s3 fitment and keeping foglights
    something to consider for a rainy day
  16. badger5
    9,599
    2,060
    low maf reading wont be the intercooler which is after the MAF in airflow terms..
  17. badger5
    9,599
    2,060
    he did say hybrid
  18. badger5
    9,599
    2,060
    and you would have made more with larger pipework and less pressure drop across smaller than OE pipework
    dyno lottery applies to figures.. According to a local dyno to me my k03 hybrid on lupo us 344bhp... lol It aint
  19. Chlippo
    Chlippo Member
    679
    15
    Of course i know intercoolers are made from aluminum and not from wood. excuse i missed to explain that its made from better quality material aluminum that disperse the heat better. Is the chinese made intercooler will be as effective as a better quality one? I don't think so and we all know that. That was what i meant. Also not to mention that the current intercooler (chinese) feels more stainless steel.
    Anyways, I ended up not fitting the evo intercooler as the piping started to be complicated, I opted for another intercooler laying around. Size is smaller but i will try it as is see what results i get.
    as for my maf readings, I have tried everything and they are still low. maybe map related but I doubt as my stock readings are low too, and I did try more than one maf (all used) with same results.
    my map is still far from perfect, but while waiting to get a decent one we will keep working on it.
    pictures and intercooler specs to come
  20. MexxT
    MexxT Member
    31
    ok, here the proof.
    Runs 95 octane + 7 liters of 96+% bio-ethanol.
    This dyno is pretty accurate, it wasn't a cold day. JD Engineering is one of the better tuners in the EU. And the superflow rollers are not ****ty rollers..
    I rolled it on the dyno at my work, that has a lot worse cooling, and it made 312hp with 430Nm.
    So I belive can say it is correct don't you think?
    I see i confused hp and bhp, it is 320bhp. here in holland we only use hp (and it means engine hp)
    but still a good result if you ask me.
  21. badger5
    9,599
    2,060
    I dont believe any dyno apart from those which match my own
    sorry
  22. MexxT
    MexxT Member
    31
    how can I prove it else? boost was 1,6 bar, and 1,9 peak.
    street tires, kw v2 suspention, stock clutch (6 speed) full powerflex, 1/4 mile 13.8 sec.
    I know what I am talking about, i work for a company called TVS Engineering, look up the projects. You can see what we build ;)
    The dyno from the plot is callibrated every 2 months.
    If you don't belive, thats ok.
    but don't say im lying;)
  23. badger5
    9,599
    2,060
    wind ya neck in fella
    i did'nt say you were lying... so dont accuse me of it
    lots of folks quote power figures from blah blah tuners/dynos etc etc etc
    done to death, and variance between them is huge. which is why this avatar is so apt ;)
    i guess yoiu have never logged your egt's with that level of boost ;)
    those boost levels are plausable for that power... i agree.. mind your egt's tho
  24. MexxT
    MexxT Member
    31
    EGT levels where fine.
    Running Ethanol the EGT will be low.
    Cracked a mani with 98 octane.
    With ethanol nothing cracked.
    Sold the turbo after a year, and no cracks at all.
    Measured on 2 dyno's would be enough i think?
    there is no offence intended, you also do great work with your hybrid and 3" tip's ;)
  25. badger5
    9,599
    2,060
    ethanols cheating :)
  26. MexxT
    MexxT Member
    31
    Bio-ethanol with 102 octane rocks :yes:
  27. superkarl
    9,610
    2,481
    Ethanol requires a bigger fuel system, 30% More fuel. so whats the deal with adding it to normal petrol, how do you work with that. different afrs required with ethanol etc. is there a limit you can add before the fuel system and mapping needs to be changed
  28. badger5
    9,599
    2,060
    wish we got choice of E85 here... that stuff looks incredible..
    good ole UK.. doh!
  29. IrishDave
    IrishDave Active Member
    682
    45
    We had e85 here for a couple of years until they decided to get rid of it. It was cheaper than regular petrol as well. Oh the Irish government, full of great ideas....
  30. MexxT
    MexxT Member
    31
    The advantage of mixxing with ethanol is that it is more detonation proof.
    And you don't need to inject more fuel. A wideband can manage it.
    So if there is no e85 or pure bio-ethanol you can mix you can just run on 95/98/102.
    with e85 i used to mix about 15L on a tank. With the pure stuff i can mix 6-7 L before it goes to limpmode.
    you can see a profit of +20bhp
    that is another reason I made my s3 apy a wideband.
    Another benefit is you can run cheap gas and stil get max power.
    here in Holland most of the extreme tuners use it.
    if i got some spare time i will set it up on the rollers and show before and after :)
  31. Jay 01 s3
    Jay 01 s3 Member
    148
    Quick question, sorry to hijack thread ; ) I can get hold of a intercooler that measures in at 650/250/90 can anybody advise would this intercooler be good enough for a s3 ?
  32. superkarl
    9,610
    2,481
    90mm is crazy thick, most of us just manage to get 76mm cores in behind the bumper sooo, i dont think its doable
  33. Jay 01 s3
    Jay 01 s3 Member
    148
    thanks Karl ; ) just wanted to pass it by ye before I went at bumper bar with the grinder
  34. badger5
    9,599
    2,060
    good enough?
    it will be like dude you seem to have a car fitted to your intercooler :)
    90mm deep core will be some serious trimming....
    how many zillion bhp you going for?
  35. Jay 01 s3
    Jay 01 s3 Member
    148
    I'd be happy with anything from 250 to 280 bill, just gathering bits before I get a map at some stage, not after mad power just want the car to run well and keep temps low :yes:
