misting up windscreen when heater is on
B5NUT Sep 9, 2013
  1. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,893
    724
    Today I have been having problems with misting up windscreen, when I put the heating on early this morning the windscreen misted up and there was a very fine layer of mist across the windscreen and the front side windows, I ended up putting the heater on full and on full heat, and had the same problem on the way home. The drive is around 100 miles round trip. The carpet does not feel damp and I check the coolant level this evening and it does not looked like it's dropped any but I am worried the heater core has a very small crack which could be dripping and causing the misting.
    Is there anything I can check, or should be looking for?
    Also is the heat exchanger a dash out job?
  2. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    377
    59
    Hope it's not heater matrix. Link here to piccies from Audifans site... deep breath!
    Brief guide to removing your heater Matrix B5 1997.. pics - Audifans.net
  3. B5NUT
    3,893
    724
    It's not the best of jobs, and could think of better things to do with my time, but had a lot worse over the years. I just wonder if there are any way of checking the matrix before I rip it out. Also anything else I should change while I'm there
  4. B5 BIKER
    B5 BIKER Member
    266
    Check Scott b5 page, I think he had the same problem and he did a fab write up with pics regarding the change
  5. B5NUT
    3,893
    724
    Cheers had a quick look, the job is not that bad just don't want to do it if that's not the problem. I'll PM scott to see how much coolant he was losing. Have to say I've replaced a fair few O-rings over the last few weeks so would not surprise me the matrix is on it's way out.
  6. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,163
    1,123
    B5NUT, does the car smell of coolant at all?
    If you put it on full and put your hand over the vents do you get any smell or moister on your hands and does that smell/taste of coolant?
    The only evidence I had of a leaking heater matrix is the smell and a slight coolant loss.
    When you buy your heater matrix I would recommend going to Audi for a new one.
    I've heard reports of others not fitting right and causing issues (Westy being the main one).
    Don't forget as well you need to drain your AC gas.
  7. B5NUT
    3,893
    724
    Thankfully no coolant smell, put a dehumidifier in the car overnight and the car was fine this morning, I am going to replace the air filter and the ECU seals as I've seen water getting into A4's after they have failed.
  8. scr8pdo
    scr8pdo Member
    199
    I had same problem on a Volvo years back, first thoughts were heater matrix "******XXX!" anyway I wasnt loosing coolant, it was around this time of year, someone who I knew who was into Volvos told me to flick the aircon on while demisting, I dont know the science but it bloody worked, it could well be a matrix problem you have, check your water level, for damp carpets etc (usual suspects) then if you find it is that a bottle of K-Seal will permenantly cure the swine, I used to buy it in bulk knocking out old bangers, its fixed more headgaskets than I remember :) and I still know of one 3 or 4 years on running fine and it was a pretty baddun at the time, the stuf is magic :)
    Also check the battery area aint got a pool of water swilling about there matey, the scuttle drains are known to block then water runs back through the heater fan!
  9. aragorn
    18,491
    855
    Check the scuttle drains are clear.
    Do you run the AC a lot? I've seen cars misting up when the AC is used lots, then turned off.
    Alternatively, if the cars getting damp inside from you getting in with wet clothes or similar, but isnt getting properly dried out, it'll go like that. My brother used to have real trouble with his S4 as most days he only drove about 4 miles to work. The inside of the glass had so much moisture on them they'd ice over on the inside!
  10. B5NUT
    3,893
    724
    The car gets over 100miles a day, the AC is just left to Auto and it's just had a regas as I replaced the compressor. I don't leave any wet clothes in the car so I can only think some of the seals are on there way out.
    I'm not going to put k-seal in the car I don't mind replacing the matrix if it has gone, it's just a lot of effort and no visible results (other than a possible leak stopped)
  11. scr8pdo
    scr8pdo Member
    199
    Are the matrix a swine to change on these? I remember changing MK5 Cortina ones in nigh on under a minute they were that easy at the time, but times have changed
  12. scr8pdo
    scr8pdo Member
    199
    I thought Id take the old girl through the car wash today ( I know tut tut etc but I not botherered) anyways after I ran it through the top wash (it gets like 2 cycles being the better program) I go in the back to get something and the youngster (2yr old) had left the damned window down around an inch or so, it was drenched in there! Not amused at all :/
    PS He was not onboard at the time.
  13. aragorn
    18,491
    855
    isnt there a rear window lockout switch to stop that exact thing happening? ;)
  14. scr8pdo
    scr8pdo Member
    199
    Dunno mate, its an early car with leccy front windows but manual rears
  15. aragorn
    18,491
    855
    ah fair enough.
    Cars with electric rears have a button to lock them out, so kids in the back cant lower them.
  16. alphaj12
    alphaj12 New Member
    19
    Daft suggestion but mate of mine had this years back and asked me about it, he had his vents set to recirculate. Switched it to take fresh air in and problem solved.
    I know it sounds stupid but though was worth putting out there.
  17. scr8pdo
    scr8pdo Member
    199
    I remember some cars like this, IIRC old MK2 Jags had them too :)
  18. B5NUT
    3,893
    724
    Only use recirculate when in tunnels, or some old banger in front spewing out the cr@p, it was OK today, just a bit on the side windows going to replace the seals at the weekend.
  19. jbh
    jbh TDi lover
    1,412
    168
    I use the recirculate when im on the m9 passing Polmont... the landfill at the side of the motorway stinks
  20. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    check your pollen filter and scuttles (or just buy a new one, the air smells cleaner after!)
    leaves and **** raising drain levels and a slight amount of water in the pollen filter and your fan is sucking moist air in
  21. davy j
    davy j Member
    i seem to havethe same problem
    Blower works but only kicks out cold air no matter where the gauge is set
    Getting too cold to run a car with no heating
    looking at pulling and replacing the matrix
    car off road for a few days (or more) lol
  22. B5NUT
    3,893
    724
    Figured I would update this thread. The heater matrix is the cause..
    As you can see it must have been a very small leak
    The bottom of the matrix is dry and there was no pool of coolant in the box.
    Removing the matrix has been a proper c**t of a job the engineers at Audi must have been laughing like hell when they designed this setup.
    New heater matrix, note the foam seal on the top of the matrix and along the side are additional parts you need to order and don't come with the matrix.
    spartacus 68 likes this.
  23. B5NUT
    3,893
    724
    Not get very far today, sheared the bar that goes between the two centre console supports, then spent 3 hours trying to find someone breaking a facelift B5 in the area and thankfully I found one.
    Don't over tighten this bar, or this will happen...
    As far as I got today the rest should be done tomorrow as long as the weather holds.
    Also anyone who has done this job or had the dash out was there any problems with rattles or creaking afterwards.
  24. spartacus 68
    377
    59
    Could be stuck thermostat if you're getting no heat. If thermostat needle doesn't rise (should sit at 90 degrees), then this could be possible cause before hauling out matrix.
  25. spartacus 68
    377
    59
    Top job B5NUT! Good luck with the reassembly.
  26. B5NUT
    3,893
    724
    Thank feck for that, car is back together and at the moment appears to be working fine with no rattles or creaking.
    I did have one problem which threw up this error code
    01271 - Positioning Motor for Temperature Flap (V68)
    41-00 - Blocked or No Voltage
    Turned out to be a lose screen just above where the arm is and it was fouling on the screw.
  27. ScottD3
    15,163
    1,123
    Its not a fun job but I think I got it down to 6 hours for remove and refit.
    The joys of doing it twice in 4-6months lol.
    What's this wood for?
    I noticed bout the foam, little bit annoyed about it. It should have came with the matrix. I never had time to order some so I reused what was on the original one.
  28. B5NUT
    3,893
    724
    It was to hold up the steering column, as much as I tried I could not remove the housing without moving the cross member, once that was moved up slightly the housing came straight out. They change to design of some of the dash parts between the PFL & FL so not sure if it had to be moved but made it easier to remove and refit the housing.
    The foam on my unit was destroyed due to the coolant and no chance of reusing it.
  29. davy j
    davy j Member
    Thought i would update you on my own problem
    Decided not to pull interior apart and checked hoses instead.
    With a little help from jbh (thanks) managed to get heat out of the system at last
    ended up replacing the thermostat and refil the system with 50/50 mix of antifreeze and water and the got the problem of misting windscreen back (bummer)
    When i went from low temp to high temp i was getting a pile of smoke coming out of the top vent (not nice when you are doing 70) and instant fog on front screen.
    Ended up leaving car running with high temp for half an hour and this seems to have sorted it (hopefully):yum:
  30. TonyH38
    TonyH38 Active Member
    273
    74
    That looked a nightmare of a job.
  31. davy j
    davy j Member
    just stripped mine today
    Pig of a job
    6 hours and still not out
    inaccessible plugs and car fighting me every step of the way
    Next time this happens the best cure.....
    scrap it and get another one LOL
  32. B5NUT
    3,893
    724
    If you had to pay someone to do the job on a car our age then you are looking at the car being scrapped, just to many hours labor!
  33. ScottD3
    15,163
    1,123
    Its not the best job to do but its worth doing it.
    Saves you loads of money over getting a garage to do and you know everything is put back correct and in the right place.
    After doing mine twice, I'll happily do it again and it scrap the car.
    It seems such a waste for a semi awkward job.
  34. davy j
    davy j Member
    car put back together at last
    gonna have to strip the wheel off again as i have no horn lol
    and airbag light on (already arranged to get it reset)
    Thanks jbh
  35. B5NUT
    3,893
    724
    Did you disconnect the battery before your started the job? I never got an airbag light on and as the horn is all part of the same harness, I think you may not have a plug not seated correctly, and if that is the case the rest won't work.
  36. jbh
    jbh TDi lover
    1,412
    168
    yip I agree with above. check you're plugs Dave you will need the light reset now that its stored a fault but as above something isint right if you have no horn and the airbag light has come on.
  37. davy j
    davy j Member
    just checking everything and no horn!!!!
    gonna take wheel off again today and have a look to see what i missed
  38. davy j
    davy j Member
    ended up the earth unplugged itself within the binacle(under the dials) got horn back but still got airbag light on.
    Battery gets unplugged every time i deal with air bags
  39. aragorn
    18,491
    855
    airbag light will stay on until you reset it.
