mistery resistor and disconected vacuum pipes
yendall24 Nov 8, 2008
  1. yendall24
    yendall24 Member
    571
    hi all i was having a look around the engine bay of my 19tdi pd today whilst waiting for the oil to drain and found some wires taped up upon further investigation i found a resistor link on the fuel temperature sender the wires had been cut and linked with a resistor soldered in also found some small vacuum pipes disconected and blanked off one of them went to a small valve just behind the drivers side headlamp and the other went to some sort of valve it was about 2 and half inch diameter and made of stainless steel that sits top left of the engine and as a sort of vacuum activated plunger on it any idea whats gone on here any advice would be appreciated
  2. Siena
    Siena Active Member
    2,626
    Hi, pictures would help.
    Otherwise, we're all assuming, and shooting in the dark.
  3. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    The resistor sounds like that dreadful "max power increase performance" shyte they sell on ebay. It sits on the temp sender and tells the ECU that the engine is cold even when hot so you get overfuelling and a supposed increase in power. Like running the car with the choke out in the good old days. If the previous owner was daft enough to fit that garbage there's no telling what else he's done!
  4. yendall24
    yendall24 Member
    571
    hi all i have been looking on the internet and found out that the vacuum pipes disconnected operate the egr valve and egr control selenoid is there a reason for doing this and is there anything to be gained from putting it back to how audi intended
  5. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    As above the resistor is known as the Evry Mod, it modified the value seen by the ECU from the fuel temp sender to increase fueling and thus give you a little more power.
    Is it the EGR that has the pipes or could it the the anti shudder valve? Normally in the body of the EGR but closes when the engine is switched off the prevent run on and shudder.
  6. yendall24
    yendall24 Member
    571
    the vacuum pipe that is disconected is the one that goes to the top of the egr valve the anti shudder valve is i think a black plastic type thingy attached to the side of the egr body it as a plunger type thing attached to a sort of flap within the egr valve
  7. aragorn
    18,579
    868
    i guess the EGR has been bypassed for the same reason as the fuel resistor, more power.
    The egr adds exhaust fumes back into the inlet to lower combustion temperatures and therefore reduce NOx production, however replacing air with exhaust gas means you have less oxygen and therefore less power.
  8. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    its a common mod to disable egr as all it does is recirculate **** and this ends up coating the inlet manifold, it can be adjusted to a very low setting with vagcom if you want to be more technical
    i had part of the inlet manifold off recently on my v6 tdi and it was covered in black hardened ****
