So... the wire for high beam is connected to the pin 11. I don't know about the rest, what they do and how they should be connected.
Here are a few pictures with mine. Notice the wire for high beam, it goes from the right side headlight to the left side than together with the wire from the left headlight goes inside the car.
My car is LHD, that's why the wires go to the left. In your case they shoud be on the right side.
L.E. I see now that the pictures are not that good. I'll take some more later. Meanwhile, you just take a look and tell me exactly to which pin that wire is connected, so I can check where it goes in the other end.
Thanks for that, this is starting to make much more sense now! i just had a look at my connections, and there is no wire connecting both headlights. I am guessing that this is the wire which has been cut, and it seems to be on pin 12. all of the other wires are connected to the original connectors. so would it now be, as simple as connecting the two cut wires together, or would i still need to plug two wires into the CE module? (like
This shows)
I have attached some errors/pics which may help.
error:
6 Faults Found:
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 136
Mileage: 181230 km
Time Indication: 0
Date: 2013.08.11
Time: 16:21:00
Freeze Frame:
OFF
Voltage: 12.70 V
OFF
ON
OFF
OFF
OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 136
Mileage: 181230 km
Time Indication: 0
Date: 2013.08.11
Time: 16:21:00
Freeze Frame:
OFF
Voltage: 12.70 V
OFF
ON
OFF
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 175494 km
Time Indication: 0
Date: 2013.03.13
Time: 22:37:00
Freeze Frame:
ON
Voltage: 12.45 V
ON
ON
OFF
OFF
ON
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 175494 km
Time Indication: 0
Date: 2013.03.13
Time: 22:37:00
Freeze Frame:
ON
Voltage: 12.45 V
ON
ON
OFF
OFF
ON
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 4
Reset counter: 133
Mileage: 179890 km
Time Indication: 0
Date: 2013.07.10
Time: 16:44:00
Freeze Frame:
ON
Voltage: 14.40 V
ON
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00110111
Fault Priority: 1
Fault Frequency: 2
Reset counter: 141
Mileage: 181058 km
Time Indication: 0
Date: 2013.08.08
Time: 17:53:00
Freeze Frame:
ON
Voltage: 11.60 V
ON
ON
OFF
OFF
OFF
Pics:
Left
right
Wire coming out of pin 12(?)
Thanks again, i appreciate it!
