Missing ABS ECU question
PJM_01 Nov 19, 2010
  1. PJM_01
    PJM_01 New Member
    13
    Hello
    I've now had my B5 2.5TDi for 6 months and am really happy with it generally, however when I bought it it was missing the ABS ECU/Module. As I'd seen loads on ebay and the like for sensible money I wasnt too worried and intended to pick up a replacement.
    HOWEVER! Having scoured eBay and contacted local (and national) Audi breakers I cant find one that matches my code!! Now time is of the essence as the MOT is due in January and its not gonna pass with a big flashing (!) in the middle of the dash and an obvious gap in the engine bay!
    Anyway to get to the point. My code is 8E0 614 111 H
    What does the "H" mean? The car has "ASR" which I think is a form of traction control.
    If I was to fit an ABS module without the "H" would the fault on the dash clear and the ABS work but mybe the ASR wouldnt?
    Help please!!!
  2. evilscotsman
    evilscotsman Space Cowboy
    1,350
    14
    the abs and asr are functions of the same hardware mate. Afaik the abs is not an mot requirement, only that the brake force is even and sufficient to pass the test. If the right ecu were used then both functions would return, but cant say about others, may need coded to the car using vag com or vcds.
    without abs you still have normal brakes. Its a modulator pump and controller thats all.
    would be better to have abs than not but you may need the exact same one as the car came with.
  3. aragorn
    18,490
    855
    If a car was sold with ABS fitted it must be present and working.
    For ease your really want to find a matching ecu, you may find the H has been superceded now though, and there may be other numbers that are the same.
  4. cerips
    cerips Member
    54
  5. PaulTheo
    PaulTheo Member
    126
    ABS warning light on is a MOT failure.
  6. evilscotsman
    1,350
    14
    ah ok sorry lads I stand corrected. Never had a failed abs but I did get a pass with the airbag light on a car, thought it may be the same as the brakes still work as intended with the abs disconnected.
  7. murran
    murran Well-Known Member
    1,545
    39
    nope, im an mot tester the light needs to follow correct on with ing on.... then off with starting characteristics.
    airbag systems are a passive safety feature, so not an mot failure. (ie; wont stop you having an accident) abs systems are an active safty feature (can stop you having an accident!) and so fail......
    tho due to vosa's short sightedness and inconsistancies.......... a damaged seat belt fails an mot...... surly that comes under the same bracket as airbag lights? being a passive safety feature???? hang on dont get me started on the bullsh1t surrounding mot's.....
  8. aragorn
    18,490
    855
    The airbag light is being braught in as part of the test in the near future, along with a pile of other amendments aimed at making the test more consistent with the rest of europe.
  9. PJM_01
    PJM_01 New Member
    13
    Thanks for the responses, looks like I'll have to try and get a matched code one way or another. Seen a few on eBay but was being tight ;-)
  10. aragorn
    18,490
    855
    Just checked for you, and the "H" code is superceded to "J".
    So H or J will work.
    H/J were only fitted to AFB and AKN engined cars (2.5TDI) as these were the only FWD models fitted with ASR
    You can find them in A4's A6's and A8's
  11. aragorn
    18,490
    855
  12. PJM_01
    PJM_01 New Member
    13
    :laugh: This very one is fitted on my car now! I saw it just before you posted this - thanks anyway! All works fine, I no longer have the annoying chime and flashing warning everytime I start the car. And my ASC button works, just in time for the pending snow........ if it ever arrives.
    All the response has been appreciated, cheers!!
