Misfiring Pd Tdi s
paul20v Jun 15, 2009
  1. paul20v
    paul20v Audi fanatic
    1,113
    Hi
    i was wondering if anyone on here has come across this
    its now happened to a mk4 golf and a sharan
    it seems that the miss is only ever cylinder 1 and after you have pulled the cam cover off the engine wiggled injector loom on number 1 cylinder the engine then runs on 4 again
    has anyone on here had a similar problem
    both engines have done between 110k - 130k
    i was wondering if it could be the loom in the head that connects to the injectors
    it also seems that that end of the loom has the most movement and maybe this is causing a broken wire or the terminals on the plug on the injector getting weak because of movement over time
    any other suggestions welcome
    thanks Paul
  2. BILKO1
    BILKO1 Member
    301
    Common fault this on the PD engines get a new injector loom from the stealers About £30 and it will be fine. What happens is the oil causes poor conections and the wiring goes hard / brittle.
  3. paul20v
    1,113
    Thanks for replying
    had all ready sorted it ,
    but thanks anyway
    the loom was £36 and it was in stock so that said it all
    cheers
    Paul
    :beerchug:
  4. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    hi was it ok a idle for a few minutes then it started to have a small misfire then was ok once warm ?
  5. paul20v
    1,113
    No there was intermittent miss fire and sometimes it wouldnt go away at all .
  6. tdi-man
    1,783
    64
    had injector 1 fault so changed all injectors and still got injector 1 fault so must be loom
  7. paul20v
    1,113
    Definately its always that end of the loom that goes ,
    when you do it you will notice that end is unsupported compared to the rest i think thats the problem
    Paul
