Misfiring only sometimes agu 1.8t
Chris_38 Jun 12, 2013
  1. Chris_38
    Chris_38 Member
    33
    On the odd occation my car use to misfire well it's done it's twice but once I turn it off and bk on it used to stop it now it doesn't I start the car an it either runs like **** or it fine , I've checked the coil packs wen it's running an they all fire except number 3 ( if u count number 1 from the cam belt ) I swapped 2and. 3 over to see if it was the coil or plug died , and it was neither the coil from 2 will not spark in 3's place which is weird , I checked to make sure none of the wire have come off the plug or the coil but nothing that I can see no burns tears or nothing , is there a knock sensor or any other sensorsthat can cause this , many thanks chris
  2. <tuffty/>
    21,580
    4,052
    Ignition control module... cyl 3 is a common victim when this goes...
  3. Chris_38
    Chris_38 Member
    33
    thank you for your reply , wat normally causes these to go , where's it located , etc , u jus solved my problem in minutes were as I've been out there swapping this an tht etc lol
  4. <tuffty/>
    21,580
    4,052
    ICM is on the airfilter box... vibrations etc affect them and its common for the internal wiring to break... its not realistically a fixable component as the internals are sealed and potted so normally requires a new ICM unit
  5. Chris_38
    Chris_38 Member
    33
    Thanks mate jus found it an tryed disconnecting it an **** but ur right lol , I'm goin to see if i can get one now before Skool run lol
