Misfire problem on 2.4 v6.
The_Mighty_Gers Apr 9, 2013
  1. The_Mighty_Gers
    The_Mighty_Gers New Member
    15
    Just had the clutch and flywheel replaced and a full service, after the service the car immediately developed a misfire on cylinder 4 (shows on the error codes) before all the work was done there was a very light hesitation in acceleration but now it misfires on idle and under load.
    does anyone have any suggestions?
    many thanks
    Scotty
  2. rjm180
    rjm180 Active Member
    581
    34
    Maybe coil pack/packs, have you had them replaced under the recall and have you scanned the car for fault codes?
  3. The_Mighty_Gers
    15
    I think i will have to speak to audi, no paperwork from the previous owner to show that if they have been replaced under the recall or not. yes i have the fault codes, shows two, 16683 and 16688 to show that its number four cylinder that is misfiring. is there a process i can use to check like swapping ht leads over?
  4. RyanJonS4
    RyanJonS4 Drive It Like You Stole It
    565
    133
    43
    could swap 2 coils, clear fault codes and try again to see if misfire mov es to a different cylinder?
  5. rjm180
    581
    34
    If you take it in to Audi they will have a look at the coil packs for you to see if they have been replaced.
