Misfire in 130 PD a4 at 1500-1800 revs
technics100 Jun 4, 2007
  1. technics100
    technics100 Active Member
    850
    25
    I have a misfire in the car which happens on and off when driving easy. It happens as I start to accelerate from about 1500-1800 rpm. It doesn't happen when driving hard. The maf was changed on the car not that long ago, so I don't think its that. Anyone any ideas what it could be. Maybe I should just clean the MAF?
    I have scanned the car with vag-com and it doesn't have any faults..
  2. Neil_S
    Neil_S Member
    248
    Does the misfire occur with the connector to the MAF unplugged? I've had lots of issues recently, replaced the MAF and they still existed, found that smearing some diarectic silicone grease on the MAF connector really helped, definately a connector issue.
    If you don't get the misfire with the connector unplugged, try the grease.
  3. bobbinz
    bobbinz Flat out ......in neutral
    15
    Had a similar problem on a 2.5ltr - not sure if it is the same thing, but the dealer suggested I had a problem with an engine mount, or more precisly a sensor on an engine mount; it cuts the ignition, (mis-fire?) to rectify vibration in the cylinder block. He went on to say that this was 'often' a problem on the 4 cylinder engines (1.9 td incl.), not too much so on the V6. ~That'll be £25 for the bit sir, oh and 100 quid to fit!! - - - I ended up puttin up with the misfire!
    Don't know if this what you have, but it may be a starting point -good luck
    Didn't mention what might cause said vibration......:tumble:
  4. golisago
    golisago Member
    Is your tuning box adjustable , if so try and turn it down a little and see if it does / gives the shudder again.......if you can't adjust it i sugguest you take it off and go for a drive afterwards.!!!
    Tuning box's :no: .
  5. technics100
    850
    25
    Hi, just a quick update...It wasn't the tuning box as I ran it boxless for a few weeks and still had the misfire. It was actually the injector wiring loom. I took the rocker cover off and tightened and cleaned the crimped connectors of the loom that go onto the injectors... Problem solved.. happy days..
  6. golisago
    golisago Member
    Nice one glad to here its fixed.
