misfire at idle 2.0 tdi 2006 auto
smm20vt May 15, 2012
  1. smm20vt
    smm20vt New Member
    since ive had this car its always had a slight misfire on tickover, recently in starting going into limp mode with a po299 fault with was underboost, i checked the turbo out and the actuator lever wasnt moving at all so i removed the turbo and checked the vanes and freed the lever from carbon build up, its running so much better, ive also changed the injector loom and stripped and cleaned the egr valve, but im still getting a misfire on tickover, the car is a auto so in D its better because the revs are are higher but much more noticable in N.
    has anybody had this issue or think of anything else i can check id rather do it myself than send to audi
  2. alastair0903
    alastair0903 New Member
    22
    would be interested to watch this thread as my 2004 2.0 tdi dsg A3 has a very similar problem . does it do it more when it is warm ? i have changed my tandem pump and cleaned the tank out but it hasn`t really made any difference
  3. smm20vt
    smm20vt New Member
    it seems a little better when its warm i think although i tend to leave it in drive most the time so i dont really know, i think i am going to block the egr valve off next and see how i go.
