Mirror Glass not heating
doeboy May 17, 2006
  1. doeboy
    doeboy Member
    602
    My offside heated mirror didn't work so i ordered a replacement from ebay, turns out its been used and they're VW mirrors, yes same group i hear you say but the connector for the heating element is different its about half the size. When changed the heating did not work on said mirror.
    Anyone else come across this? Should these smaller connectors still work? meaning it's possible the wiring or something else is a-miss,
    I don't want to pay for another mirror and find that it's the wiring thats knackered!
  2. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    use a multimeter on the mirror.... its just a circuit, and resistance in the wire causes it to heat and warm the mirror...Check theres a circuit...if there is, the the wiring is at fault!
  3. doeboy
    doeboy Member
    602
    Took it to my dads this morning where he checked it over.
    Current fine to Mirror wiring, Low resistance on the mirror that was considered faulty, so thatÂ’s pretty much knackered! Ordered a pair of an illiterate idiot from ebay, one is open circuit so knackered and the other again is low resistance! He sent me another one today but I don't hold out much hope! I shall just order from vag parts I think!
  4. CraigM
    CraigM Member
    100
    If it is open circuit try sticking it in the freezer for 5 mins as they have a temp switch fitted to them so they aren't on all the time.
  5. doeboy
    doeboy Member
    602
    Open circuit means there is a break in the circuit so current will not complete the curcuit.
    The ampage was tested from both mirror connectors and was the same. so it really looks like its the mirrors! Mine had gone and the second hand one i bought was duff also. By ordering one from a vag dealer it should work!
  6. CraigM
    CraigM Member
    100
    The open circuit mirror is caused by the temp switch on the back of the mirror glass - when it is cold enough it will close the circuit and switch on.
  7. doeboy
    doeboy Member
    602
    Ok we'll see tomorrow. Still doesn't explain why one was working and the other not. The plot thickens!
