Milltek fitment question for Sportback owners
H17YD L Jun 26, 2013
  1. H17YD L
    H17YD L Active Member
    383
    76
    I've had my milltek on a few weeks but can't help but notice the pipes sit in the recess a lot! Plus they are on the pi55 when u look at them lol. Is this how everyone's look, only reason I never bothered to ask before was my original always sat a bit wonky what do you's think?
  2. nil538
    nil538 Active Member
    499
    66
    They should sit level and straight are you sure you haven't got a 3 door version as they are shorter in length than the sportback version could be the Reason why its sitting back in from your bumper or it mite just need a little adjusting as the Joints might be slid on too far
  3. TDI140
    TDI140 Well-Known Member
    1,624
    174
    For the tdi sportback milltek said thats the gttdi mk5 5 door and 3 door is the same as the sportback audi a3 one but on the 3 door a3 its slightly shorter, but if your not happy with it jack the car up from behind and loosed the clamp where the back box connects onto the centre pipe and pull the back box out a bit and clamp down as hard as you can so its secure then pull tail pipes out a bit aswel to as far as they go and clamps tight again, should sit better by doing that 30minute job, also if you think tail pipes are angles more than usual you have to swap tail pipes over as you may have wrong one on wrong side
    ive purposely left mine slight hidden on my tdi due to dirty black smoke from remap lol but wipes clean with dry tissue wouldnt ever buy any other exhaust system again, my car doesnt even sound like a diesel under throttle
  4. TDI140
    1,624
    174
    I say yours sits quite nicely same sort of distance out of the valance as mine on my sportback
  5. H17YD L
    383
    76
    Well I did think it was a 3 door when I realised but the numbers tally up with the one for the Sportback.
    I can't pull it out any further as it starts to hit on the subframe!
    So if I try an push the tips out it'll make that touch the subframe.
    What do you mean about swapping the tips over? Mine are welded on to the back box.
  6. TDI140
    1,624
    174
    Your tips are welded ?? :-/ thats weird how old is the system ?
    my tail pipes can be adjusted to sit further in or out, i personally think your exhaust sits nicely mate
  7. Dikonou
    Dikonou Member
    43
    Probably the tail pipes are for the 3door......had a similar problem and the reason was that the dealer, not miltek, had send me the 3 door version of the tail pipes.
  8. H17YD L
    383
    76
    The system is brand new. Here's how the tail pipes look
    And here's how it look from the side to give a better view of how far in it sits
    The back box has the stamp on it for a Sportback so if it is a 3 door box milltek have stamped the wrong badge on?
    If that's how other people's Sportback systems sit I'm not bothered but my mates Polo GTI system sticks out flush with the surround so you can just see the milltek stamps on the top of the pipes
  9. TDI140
    1,624
    174
    If his tail pipes are wrong it means the whole back box is wrong as the tail pipes are welded to the back box
  10. Johnny Bravo
    Johnny Bravo 6+1 Gears Bronze Supporter Audi A3
    898
    69
    The new models can be adjusted. On the older ones the tips are welded and can't be adjusted.
  11. Dikonou
    Dikonou Member
    43
    Is the rear Sline?:think: Could that make the difference?
  12. H17YD L
    383
    76
    So we are saying that this is somehow old stock and they make a newer system where the tips can be adjusted?
    It's an S3 so presume milltek made it with the S3 rear bumper?
  13. TDI140
    1,624
    174
    Milltek for the s line and sport is same system as i had mine fitted when i had sport bumper on rear but then changed for s line bumper, the s3 system is a totally different one to the a3's, as said above yours is the older system thats why exhaust tips cant be adjusted mines only about 4 months old
  14. H17YD L
    383
    76
    Milltek will be getting an email! Only bought it a month ago.
  15. H17YD L
    383
    76
    Milltek got back to me and said all the Sportback systems have the welded tips? But you say yours are adjustable?
    They want to see more pictures of the hangers so sent that off to them today, hopefully get a response tomorrow.
  16. TDI140
    1,624
    174
    Well heres my tail pipes taken off as i was adjusting them
    image.jpg This is before i adjusted them so they look a bit bent in the picture lol
  17. H17YD L
    383
    76
    He must of meant the S3 Sportback system is welded, good job you were able to adjust yours lol
  18. TDI140
    1,624
    174
    Yh maybe they are just welded on the petrol models due to generating more heat and possibly spitting flames etc
  19. Feeley93
    Feeley93 New Member
    10
    sorry to drag up a old thread, will a 3 door exhaust system fit a 5 door sportsback i have a audi a3 2.0 tdi 8p? as i csnt find one anywhere they are all for the 3 doors
  20. Marshy
    Marshy Settled in Audi RS3
    1,352
    468
    The 3dr exhaust is a few inches too short on the sportback.
  21. Feeley93
    Feeley93 New Member
    10
    do u know of any exhausts that are made for the sportback? i cant seem to find them anywhere
  22. Marshy
    1,352
    468
    Depends on what your willing to spend.
    Bcs would make one for you and Milltek offer exhausts for the sportback but either of them will cost you over £400 though.
  23. Feeley93
    Feeley93 New Member
    10
    thats what i was looking at spending just fed up of the old looking one i have on there atm and i prefer the sound of the milltek but could only see ones for the 3 door on there sight, would it be worth calling them up?
  24. Feeley93
    Feeley93 New Member
    10
  25. Marshy
    1,352
    468
    You need the one without DPF so you'd need to ring them as you need the centre section from a 3dr one and the rear section from one of the later sportback ones.
    If I was you I'd ring Nige at bcs tell him what your after and he'll sort you out, it'll be cheaper than Milltek and better quality.
  26. Feeley93
    Feeley93 New Member
    10
    okay thank you ill give them a call tomorrow
  27. Mat1987
    Mat1987 Member
    62
    31
    Hi mate, only just seen this and I know you have an S3 but i had the same issue a month ago on my A3 and what milltek found was the s-line bumper is a lot deeper so the tailpipes needed another 50mm of pipe added to them. The tailpipes are adjustable on the A3 system and I have attached the photos of before and after milltek sorted the system.
