Milltek Doesn't look right
solaris May 8, 2010
  1. solaris
    solaris Member
    416
    17
    Hi,
    Just fitted a milltek cat back system on my DTM however im not happy with the looks as the tail pipes stick out far too much from the rear diffuser something is not right, im gonna get the car up on a ramp and double check the part numbers for each section in the mean while can I request milltek owners to post up side pictures of the rear bumpers showing how much the pipes should stick out?
  2. Yellowtrophy
    Yellowtrophy Member
    108
    I had the same problem on my B7 Cabrio when I had the Milltek fitted. They stuck out about 1" more than ideal, so basically I cut 1" off each of the tailpipe finishers. You also will have to extend the slots (when you look there are 4 slots on each tailpipe finisher where they connect to the exhaust so they can flex and grip when tightened). All put back together, and it looks perfect!
  3. solaris
    solaris Member
    416
    17
    Mine stick out more than 1"...... the car behind could crash into them lol!
  4. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,006
    771
    That looks wrong, it's should only stick out when the exaust system is hot!
  5. Fireyjack
    Fireyjack Member
    105
    Certainly looks 2" too long.
    Do you mind me asking how much the Miltek exhaust was including fitting?
    also what incraese in performance they quoted.
  6. rowdyboy
    rowdyboy Member
    804
    19
    I take it that is a joke!!! Lol
    it does look very wheelbarrowish mate, sorry. Are the hangers on correctly??
  7. quattrojames
    14,068
    585
    It's true! I've heard the heat can make them expand by up to an inch.
  8. B5NUT
    4,006
    771
    As above, I had a milltek system which was fitted by the factory, it expanded when hot and stuck out by at least 1cm.
  9. Dazmo
    Dazmo Active Member
    1,762
    Were still talking about exhausts here...right?
  10. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,766
    355
  11. rowdyboy
    rowdyboy Member
    804
    19
    I will have what you are drinking mate!!! That's b******s. Lol. A few mm maybe but an inch is a bit far fetched.
  12. quattrojames
    14,068
    585
    I was only trying to help the OP by repeating what I had heard. I don't know if it's true or not.
  13. rowdyboy
    rowdyboy Member
    804
    19
    Yeah, fair enough. Sorry if it sounded a bit abrupt.
    There is obviously either a design or fitment fault as it definitely does not look right, I think we all agree on that.
    I would definitely take it back.
  14. Buster the Dog
    Buster the Dog New Member
    15
    Personally I think they look good sticking out a bit further than normal, but then I am not sure if my opinion is good as I do not think that the silver/chrome coloured wing mirrors look good, I much prefer colour coded mirrors especially on a black car as I have. I also do not understand the excitement about A6 wheels!
    Buster
    PS do any of you guys go to Le Mans?
  15. marcl
    marcl New Member
    10
    i didnt like how far mine stuck out especially when hot or how big they were
    So i threw mine away and had some less dramatic pipes on.. £50
  16. solaris
    solaris Member
    416
    17
    Ok I jacked up the car and checked all the part numbers. They are all correct and correspond to this model (Confused):-
    MSAU297 Large-bore Downpipe
    MSAU258 'Y' Piece
    MSAU259 LH Centre Section
    MSAU260 RH Centre Section
    MSAU261 LH Rear Silencer
    MSAU262 RH Rear Silencer
    MSAU298X2 100mm Trim Assembly - Dual Jet
    Time for some cutting I suppose ...I rekon I can sort this out..watch this space.
    Oh and in response to your question Fireyjack I paid £680 delivered (AmberPerformance) for the full cat back system, I fitted it my self.
  17. Buster the Dog
    15
    Those look good, but just think how much better the back would look if debadged, keep the roundels though.
    Buster
  18. solaris
    solaris Member
    416
    17
    Right I have cut the rear pipes about an inch and adjusted the hangers to lift up the rear silencers. Looks ok now, enjoy:-
  19. rowdyboy
    rowdyboy Member
    804
    19
    That's better mate, they look perfect now.
  20. Dazmo
    Dazmo Active Member
    1,762
    very nice mate, now tell us how it sounds, how much it cost you and what its like on the motorway? as i am thinking of getting one myself, but £700 is alot for an exhaust!
  21. solaris
    solaris Member
    416
    17
    The exhaust sounds alot meatier when giving it a few revs on idle, I can't say i've noticed a difference in power, during driving the noise is not too intrusive. Its exactly how I wanted it to be. I have a few other mods that should complement the exhaust but all shall be revealed in time.
  22. marcl
    marcl New Member
    10
    All you need now is a nice induction, rail pump and remap file..
    Ive have evom induction, Autotech fuel pump (although i hear KMD's is the same but cheaper) and GIAC software!!!!!
    then go find some rs4's they wont be so smug then :asskicking:
  23. solaris
    solaris Member
    416
    17
    Where can I get the evom induction kit from? and how much are they?
  24. jwhat
    jwhat Member VCDS Map User
    541
    It looks perfect now.
  25. quattrojames
    14,068
    585
    Sorry to drag up an old thread, but I've read again today about how much an exhaust can expand due to the heat - the full thread is HERE
  26. jey
    jey Member
    229
    sure the tails on the milltek like others im sure are adjustable as in how far out or in they sit.
