Mileage difference from cluster to ECU
Icey Mar 28, 2014
  1. Icey
    Icey Member
    121
    13
    Hi all
    My manager has an audi a4 and just got a cable from the states.
    i have done some mods and on auto scan it comes up the vin number and mileage ok as on dash.
    now when I access the Application tab on VCDS. And read mileage from EcU it comes up nearly 10k more.
    From 73331 to 83kish.
    does that mean it's been clocked ? I know it's 5% but that is more than 10% actually.
    Thanks for your help
  2. Icey
    Icey Member
    121
    13
    Anyone ?
  3. s3joe
    s3joe Active Member
    560
    79
    Looks that way
  4. a3-205gti
    a3-205gti Member
    42
    Do old MOTs add up and maybe check vosa website
  5. hades-
    9,481
    646
    on mune it comes up in kilometers so looks more as the clocks are in miles
  6. Sidhu88
    Sidhu88 Active Member
    808
    76
    I've always seen slight differences on most cars i've worked on. some in the hundreds most in tens. Not as much as that though
  7. hollow
    hollow Well-Known Member
    1,404
    162
    probably been clocked in between mot's even though there is usually a slight difference between ecu and dash .
  8. Icey
    Icey Member
    121
    13
    When I read the ecu in vcds it comes up as mk and miles so there is no confusion of miles or km's
  9. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    Mine is massively different too. I've been meaning to look into but I haven't been that concerned.
    One reason is because when I scanned a neighbours car for fault codes there was one that had been logged with a date prior to when the car was built. It didn't give me a lot of confidence in the data in the ECU.
  10. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Its not hard to correct mileage in both ecu and clocks, maybe its had a replacement ecu in the past? Either that or whoever clocked it was just lazy. That mileage difference indicates either clocking or a previous failure for sure.
  11. Staz
    6,206
    64
    I've had my car since new so I can assure you it's not been clocked.
  12. steviedee
    steviedee Member
    50
    12
    What I was told is that the clock mileage is not that accurate! mine is the same.
  13. Icey
    Icey Member
    121
    13
    Where and how much would it cost to have e mileage corrected ?
    We are not trying any illegal stuff to do just so both mileage add up.
  14. Artimus
    Artimus Shortback
    2,014
    483
    So the ECU mileage is more accurate? Any way to calibrate the clocks to the ECU?
  15. sliced
    sliced Drive safe, stay alive.
    1,556
    334
    £70-150 depending on where you are based. type in mileage correction into google and a whole load will come up.
