Might be buying a RS6 quick question.
BILKO1 Aug 11, 2010
  1. BILKO1
    BILKO1 Member
    301
    I've found an RS6 that i quite fancy but i am a little worried that it's not what it seems. I went online to get an insurance quote and when i put the reg number in it came up as a S6? I'm going to look at it over the weekend is there a surefire way of proving it's a real RS6 and not an S6 modified into one? The seller has all documents etc and says it's hpi clear (i'll do my own checks as hpi is unreliable).
  2. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    Vehicle Data Sticker(1) and the Vehicle Registration Certificate(2) and the HPI report itself (3) are your best bets I would say...
    1) The Vehicle Data Sticker is usually affixed to the inside front-cover of the service record, and another copy inside the spare-wheel well. This lists all softs of information about the vehicle - there'll be a "Sales Type / Model" field somewhere toward the top of it - it's normally six characters, and will state exactly what model, configuration and trim level the car is. Additionally (and probably more simply) on this sticker, you'll have the engine and gearbox codes, if it's a C5 RS6 (the first one), it'll have BCY and an RS6+ BRV. I couldn't tell you the gearbox codes off the top of my head. It'll also show the full vehicle identification number...
    2) ...Which should marry to that on the V5, which should also indicate that the model is RS6/RS6+/plus.
    3) ...Which should marry to the HPI report confirming that the other paperwork you've seen is genuine and accurate.
    It's fairly common for insurance 'poke your reg in here' boxes to be somewhat misinformed, particularly with models that never sold in massive numbers; very often they just get lumped into the next nearest thing which does have a category set-up. Hopefully this is just another case, but using the 3 bits of paper above you can get things a little clearer...
    All the best,
    Rob.
  3. pjmspeedy
    pjmspeedy Dude, what's mine say ?
    1,058
    Give me the reg of it now and I'll tell you if it's real.
  4. BILKO1
    BILKO1 Member
    301
    I just popped in to the local Audi dealer and they confirmed it's a real one:)
  5. Marc1
    Marc1 Member
    728
    Don't forget to update us with pictures, spec list etc if you do buy it. Oh and good luck with the purchase.
