MIGGZ's A3 1.8t - The all rounder build thread
MIGGZ Nov 26, 2012
  1. Scullies
    Scullies Well-Known Member
    1,543
    657
    Nice one cupcake :thumbsup:
    Did anyone get mugged/stabbed/shot while in dirtbin? :lmfao:
    That mk1 GTS looks nice, whats everyone looking at in it ?
  2. MIGGZ
    MIGGZ nanananananananan BATMAN
    1,461
    304
    page 25 belongs to you!!!
    thanks creamcake!
    no sir no one did but does it count that i shot the whole of dirtbin with wotbox then went to the shooting range and shot some real guns?
    people were seeing how original it was
  3. MIGGZ
    1,461
    304
  4. JOSEA3T
    JOSEA3T Stock Standard
    91
    Hey my bru..
    Looks like you had lots of fun and glad no mishaps happened.
    let me know when you start working on your car, would like to pop around there to you for a visit over a weekend if that would be cool with you.
    Joe
  5. PDBoosted
    PDBoosted Active Member
    242
    MIGGZ!! Long time bud... Your car has come a long way. Congrats on the power dude. thats some next level sh1t right there! DUBrun looks like a blast! Hopefully one day I'll be able to join along for the event. Keep well bud!
  6. MIGGZ
    1,461
    304
    Dude anytime you want hey! This week and next ill be with the S3 then its my car
  7. MIGGZ
    1,461
    304
    Wow!!! You alive dude??? Its been like so many months you been hiding away from the worlds!
    Dude dubrun was epic hey!
    Thanks bud
  8. PDBoosted
    242
    Hahaha I am alive indeed... I haven't been on this forum in a while though so I thought I'd drop by and see what all you got up too. I see your been busy too with your business and working other cars instead of on your own, LOL. Dude 223wkw must be savage!
  9. MIGGZ
    1,461
    304
    Need 6 speed and lsd now lmao
  10. MIGGZ
    1,461
    304
    wow over month since iv done any updates on here.......
    been busy with my car the last week or so including dropping box 4 times :keule:
    so i have a valeo smf kit that i was told is the smf replacement and vr6 clutch kit would just bolt on.... well wrong!!
    After fitting clutch and and box back and finishing up with the car it started and and as i put clutch in clunking noises!!! did reading and symptons showed and thrust bearing is scew, dropped box and checked and it seemed fine, so put back and noise again, so i drop box again to check pressure plate and re tighten screws and all that saw no issues, put back and noise again!!! so dropped it again! this time i took new clutch plate with old pressure put it all back and boom no more noise!!!! but clutch was slipping like a mofo and pedal felt weird.
    So i was at the point of burning this car!!! we checked that the fork was going to far and touching the ears on the pressure plate but why was it touching!, we took a valeo fly wheel and took a vr6/abf fly and mix and matched 3 kits sachs, luk and valeo. we found the issue, the reses on vr6/abf is 12.4mm and valeo is 11.3mm so if we skim the valeo fly wheel by 1mm my issues will be sorted and ill be able to use the vr6 kits with no issues! once again i was the test dummy on these kits.
    but on that note here is box out and getting cleaned
    then decided to take tappet cover, intake and all the boost pipes out. noticed my boost pipes were all cracking and assume it was leaking so took it to dusty to get fixed, but alas the boost pipes cant be fixed, found out that the previous builder that cost me a little package to build them did me in nicely by using 4 different grades of steel even exhaust steel and stainless coated steel so i got lekker shafted on that one, would explain the cracks and the rusting issues, so when i have time ill be making all new boost pipes as well as a 100mm induction to go with my TWEEK performance race filter.
    once iv done with the boost pipes ill be eliminating as much of the blue vac lines as i can!
    JOSEA3T likes this.
  11. MIGGZ
    1,461
    304
    next up was cutting a nice hole in my cradle for future intake
    some new shock tower mounts, ball joints and powerflex lca bushes
    then fitted a n75 on and off switch awesome idea from the well loved nick aka prawn
    then from taking that stupid box out so many times the bracket mount on the box stripped
    so got a new 2nd hand one from ernest and foursprung
    so far car feels good next up is boost pipes and intake then see if the clutch will handle or ill have to drop box again and do a copper clutch
    JOSEA3T likes this.
  12. Sixty 9 GP
    Sixty 9 GP Member
    49
    Nice updates Miggzy! Alot of hard work here I see...
    Ps. Why the On off switch for the N75? what would be the purpose?
  13. MIGGZ
    1,461
    304
    Got the idea from nick, switch off n75 and i run on actuator pressure so ideal for short track where traction is a issue and switch it on when you want to overtake so then full boost. Also the way I see it you run less boost means less stress on all the parts so full out at kyalami with out stress of heating up
  14. Scullies
    1,543
    657
    So you must be pretty fast at dropping gearboxes these days :)
    When you feel like burning your beast, just focus on the good times. It works for me.
    I also have a n75 switch and thought about flicking the switch at WOT, but a little bit worried about going from 1 bar to 2 bar in a flash.
    Scary visions of the turbo taking a KAK.
  15. MIGGZ
    1,461
    304
    Lol yeah iv gotten good lol.
    You don't need to worry about that there is about a 5seconds delay on n75 switch lol
  16. MIGGZ
    1,461
    304
    Yay clutch is slipping again from 3rd on wards so dropping box again Monday.
    Taking fly to get the reses to 12.4mm then hopefully the Luk plate is still ok then fitting it with the new Luk pressure plate that i 1st tried to use then hopefully it will be sorted or I'm going to have to go copper clutch fml
    JOSEA3T likes this.
  17. MIGGZ
    1,461
    304
    clutch is sorted so far!!!!!! very happy, fly wheel skimmed to a 12.5mm reses did the trick!
    finished up at about 12 last night and went driving around pushing the car and 4th gear labor and no slipping and clutch feels good.
    i must have a little vac leak or boost leak somewhere so after shooting tonight i might have a look at it or ill do it tomorrow
  18. Scullies
    1,543
    657
    Is that a box off job :)
  19. MIGGZ
    1,461
    304
    lol NOOOOOOOOOOO :moa:
    its the charge pipe im sure its scew was doos tired last night when i was fitting the final stuff back
  20. MIGGZ
    1,461
    304
    JOSEA3T likes this.
  21. MIGGZ
    1,461
    304
    and it was the charge pipe it was coming off! fixed it last night and today took it for a wash and wheel alignment and saw car is spiking at 1.6 bar and is killing the tyres!!! i normally boost at between 1.4 to 1.45bar but when i pushed last peak recall on the gauge it said 1.6! ill reset it when i get home from work then ill test tonight when i go for a nice long drive and check what im boosting.
  22. MIGGZ
    1,461
    304
    hey guys
    So wanted a shift light so i wont have to constantly check my rev counter on track days especially the tight stuff.
    Did some research and there were to many back and forth stuff saying i either need a special unit to work with tach or i need to splice into my ecu harness or cluster and i was not willing to take the risk incase something pops.
    So as i have wotbox i read there was a function on there for a shift light and you can buy a cable for it for X amount of $ then put a led in your dash. but did not like that idea either. So i got the 9 pin cable and started to make my own harness and used a Glowshift 10 series add on external light
    this is the plug i used
    then all connected up with momentary switch
    cleaned off that rubber **** that was on the housing with warm water and a sponge.
    drilled and screwed the light in and made a small hole for the cable
    and put it all back and set shift light to 2000rpm to see if it works
    and boom its done!!! overall took me like a hour and easy to do. Nice and bright and will warn you
    JOSEA3T and Jay A3 like this.
  23. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,120
    353
    Nice work miggz. All that wiring had warned me off haha... Did you look at prawns one? His one looks well easy to install...
    MIGGZ likes this.
  24. MIGGZ
    1,461
    304
    no??? never even knew nick had a shift light?
  25. Jay A3
    2,120
    353
    Pretty sure he has unless I'm getting my wires mixed up. I think it's one where you rev up to a third of where you want limit to be. I.e 2500rpm if you want the limit to be 7500...
  26. MIGGZ
    1,461
    304
    **** now i dont know ill ask him quick
  27. Jay A3
    2,120
    353
    Doesn't matter, your install looks nice. Bit bright as you say maybe drop in a resistor to dim the bulb down
  28. MIGGZ
    1,461
    304
    that pic was taken at night with flash its really not as bright as you think, i would want it brighter for day time use, besides how often does one take the car to 6k rpm normal driving?
    and thank you for the kind words mate
  29. Jay A3
    2,120
    353
    Quite often :p. there's about 5 sets of lights road by me and all on straights lol
  30. MIGGZ
    1,461
    304
    bwahahahahah i normally shift at like 3500 as thats when the intake sounds the nicest, only time my car sees high rpm is a TLGP, traction loss or for videos (which i have not done in a while lol)
  31. Jay A3
    2,120
    353
    I agree shifting around 3.5k to 4k is nice.. Can't wait till it's mapped!
  32. MIGGZ
    1,461
    304
    yeah how long still bud?
  33. Jay A3
    2,120
    353
  34. MIGGZ
    1,461
    304
    lol double post?
  35. Prawn
    11,403
    3,283
    Mine's a simple little box of tricks, 12v and ground connections, and a single splice into the ignition amp feed on mine. very simple indeed.
    To set it, you enter a calibration mode, then rev it to half your chosen RPM and release the button. Done.
    Car is looking good Migs. Shift light is a cool addition :) where have you got it set?
    Jay A3 and MIGGZ like this.
  36. MIGGZ
    1,461
    304
    ooooo ok yours is easy then what is yours set to rpm wise?
    thanks bud
    i have not really set it yet dont know where i should yet was thinking 6k rpm, and thank you again lol
  37. Jay A3
    2,120
    353
    Cool, I wasn't get mixed up! Prawns setup sounds easier. November miggz ;)
  38. MIGGZ
    1,461
    304
    lol it is easier but thats cos you guys have agu! dont have them amp thingy lol
    only november i would die before then
  39. Jay A3
    2,120
    353
    Only reason why I'm cleaning headlights! Bored otherwise
  40. MIGGZ
    1,461
    304
    in that time you could paddle to me and clean mine then paddle back if you really bored lol
    Jay A3 likes this.
