Mi11arsW.I.P
Mi11ar May 28, 2013
  1. Tim_Attard
    Tim_Attard Active Member
    473
    44
    its one of the easiest mods ive done, did it on the drive on axle stands, just make sure you soak the lambda and bolts otherwise they are a pig to get off
    JudderMan likes this.
  2. Mi11ar
    Mi11ar Active Member
    316
    35
    I've been told if you fit them without a map you can encounter problems with fuelling and such, so I'm holding back fitting them until I've done a few other mods first and I'm ready for a custom map.
    Pubemammal likes this.
  3. Pubemammal
    Pubemammal Active Member
    525
    117
    43
    Keep up the good work mate. What other plans you got? Keeping the standard wheels?
  4. Mi11ar
    316
    35
    Thanks buddy, I'm looking towards more power, big brake conversion and the big decision Ko3s or Ko4!? Considering I'm keeping the Car for the foreseeable future I'm thinking of going for the Ko4 option since I've the time to collect the supporting mods etc
    As far as cosmetic is concerned I have the S3 side skirts and S3 Rear Bumper already they are taking residence in my friends garage but since the S3 has the wider arches I'm not sure it will look right so may just clean the Car up and go for a re-spray, possibly include an S3 spoiler aswell.
    The wheels will remain the same until I've focused more on power, I've promised myself new wheels after I brake the 230bhp point, Pourche Boxter alloys or BBS.
    Opinions?
  5. Pubemammal
    525
    117
    43
    I was under the impression you can just bolt the k03s on and get it mapped. With the k04 I think theres alot of other things you have to get. Theres a really good thread on here somewhere that explains it all. Written by jardo
  6. Mi11ar
    316
    35
    Yup your right, but with the Ko3s you still have limitations as regards to power, unless you go down the Hybrid route.
  7. Tim_Attard
    473
    44
    k03s is good tilla round 240ish as far as im aware, u can obviously go alot higher with k04 but its a lot more work such as new DP etc it really comes down to, will you be happy with 240bhp?
  8. Mi11ar
    316
    35
    I think I'd be happy with 240, but having the option to push it further is always nice, how much extra work are we talking about?
  9. Tim_Attard
    473
    44
    iirc it will mean a new lot of injectors, maf, tip, down pipe, ex manifold, fual reg? (not sure), new piping for intercooler
    not sure what else but im sure there is more.
    my turbo is on the way out so looking into getting another k03s as it would be too much money, time and effort to go k04 and im happy with my hp as its a daily (need to get it dyno'd but think im around 230-240)
  10. Mi11ar
    316
    35
    Ko3s it is then, more parts means more parts to replace if anything goes wrong and it's also my daily, I do allot of miles in the Car due to work so I don't want to sacrifice reliability either.
    Was yours originally a Ko3?
  11. Tim_Attard
    473
    44
    no i have a 2003 aum so was a k03s, tbh if i had a k03 i would have waited and saved to get all k04 parts but as you have already started go k03s will be good
    Mi11ar likes this.
  12. Mi11ar
    316
    35
    Brake light switch failed so replaced that today
  13. Mi11ar
    316
    35
    Ordered some service parts:
    Castrol Magnatec 5W-30 C3 Fully Synthetic Engine Oil
    Bought new Aero wiper blades because my last ones were done with, and the new ones look more modern :)
    Also got the bosh 4 prong spark plugs and a few other bits and pieces
  14. Mi11ar
    316
    35
    Oil light came on and shortly after engine seized, I've narrowed it down to it being an Oil Pick Line problem think because I failed to change the oil early enough after doing almost 20kMiles since May the Car just gave in.
    So I've ordered a newish engine with only 70k Miles (last had 120k) it comes with a Turbo and ECU (So I have spares) it's getting a cam belt change and full service before fitting.
    Along with my FMIC, 3'' Down pipe and De-Cat, and then a remap, I'm still deciding on whether to end with a Ko3s or Ko4 not sure.
  15. dusty
    dusty Active Member Team Nogaro Blue Audi S3
    267
    46
    Bad luck, I would change the oil pick up on your new engine there only a few quid from the dealers, not a big job
    Mi11ar likes this.
  16. Mi11ar
    316
    35
    Yea definitely wanna avoid that happening ever again, apparently it's a common fault as it's a poor design
  17. Mi11ar
    316
    35
    So as I said earlier my engine seized, since then I bought a newer engine 74k miles for a bargain price of £395, I then got it fully serviced including a new cam belt.
    Along with:
    FMIC
    3'' de-cat and down pipe
    New uprated clutch
    And my new Kenwood head unit
    I also sorted out my window tinting that wasn't looking to good and now is :)
    Here are the pics anyway -
    Old seized engine
    De-cat compared to cat
    FMIC
    Engine
    Finished
  18. Mi11ar
    316
    35
    Next on the list is:
    Ko4 upgrade inc supporting parts etc
    Decent rims
    Re-spray the roof and any areas showing signs of ageing
    HID upgrade
    Custom rolling road map
  19. Mi11ar
    316
    35
    The sump that came with the new engine had a leak
    So we got the sump from the old engine and cleaned it out to use on the new engine
    http://s80.photobucket.com/user/Sir...5108_251882182_n_zps7cbc28f4.jpg.html?filters[user]=17028099&filters[recent]=1&sort=1&o=10
    http://s80.photobucket.com/user/Sir...0108_657105403_n_zps0485501a.jpg.html?filters[user]=17028099&filters[recent]=1&sort=1&o=6
    Changed the oil filter
    I then done a rear wiper delete
    I then fitted some clear Xeon bulbs to get rid of that old yellow ones
    A sky view of the Car in the workshop
  20. Mi11ar
    316
    35
  21. Sham101
    Sham101 Member
    286
    20
    im asian my self but chrome is paki fide
  22. Mi11ar
    316
    35
    Not to everybody's taste but I'll keep them for now
  23. Mi11ar
    316
    35
    Car was back in the garage for the third time this week, this time it was miss firing, the computer showed up it was a cooling temp sensor so I bought one:
    After fitting that I soon realised that the problem was still not resolved, so back to the drawing board, I changed all the leads and bought new BOSH Super sparks, that solved the problem happy days!! :D I'll post pics of the state of the old sparks they were destroyed I was told when I bought the new engine it had a recent server (apparently I was lied to)
    Anyway got some new stickers for the rear:
    An I removed the chrome wing mirrors:
  24. Mi11ar
    316
    35
    All cleaned for Christmas :)
  25. Mi11ar
    316
    35
  26. Mi11ar
    316
    35
    After getting a new engine and spending loads of money on my Car, it sadly came of the road during 1 rainy night and done a fair amount of damage: Air bags deployed, cracked my sump, put a big hole in my gear box, crushed the power steering lines, bent my FMIC and loads more.
    Everyone was telling me to scrap the Car and buy another along with loads more abuse, but this has only spared me on more to repair the Car, I've bought all new parts and upgraded the clutch to a solid state and flywheel.
    Here are the pics I'll post more as the restoration continues :)
  27. Mi11ar
    316
    35
    New gear box and sump ready to be fitted:
    So in these most recent months the Car has had:
    New engine
    New gear box
    New Clutch
    Then replaced the new clutch for a solid state clutch
    FMIC
    Then replaced the FMIC because I bent the old one
    3'' Down Pipe and De-cat
    Cam-Belt and water pump
    New power steering lines
    New air bag unit
    Welding in places
    New front bumper
    Full service
    XEON Lights
    De-wiped rear
    Plan to have a Ko4 conversion soon, and re-spray the roof of the Car :)
  28. :: blade ::
    :: blade :: Active Member
    343
    31
    looked good that mate, shame about you giving it a bump, where abouts in the north west you from?
  29. Mi11ar
    316
    35
    Cheers near Ormskirk, I'm in the forces and based else were though, it will all be sorted by Friday I'll post pics when its done :)
  30. :: blade ::
    343
    31
    ahh reet, cool beans :)
  31. JoeeS3
    JoeeS3 Active Member
    464
    105
    43
    sorry to hear about your car millar, can i ask what you did with your old clutch? (the new one) and also i have k04 with working internals, only problem is the housing has cracked so if you can find uncracked housing going cheap you can have the internals at a cheap price. will be nice to see your car all back together and working again though
  32. Mi11ar
    316
    35
    I've left it with the mechanic not sure what I'm doing with it tbh, an that's decent I actually know someone selling the housing all I need is the core :p
    I'll post more pics when it's finished :)
  33. Mi11ar
    316
    35
    More progress on the Car :)
  34. Mi11ar
    316
    35
    A friend was selling some decent harnesses so I bought them from him, I do plan to eventually get some nice bucket seats and have them fabricated cream leather to go with the rest of the interior, but I'm actually happy with them at the moment.
    Car was supposed to be sorted today but when we checked everything to make sure it was all ok, we discovered a leak in the radiator so it looks like tomorrow Dinner time that we will have it finished.
  35. Mi11ar
    316
    35
  36. Mi11ar
    316
    35
  37. Mi11ar
    316
    35
    Bought some new Alloys I can't fit them yet though because I need the adaptors they're 5x115 and I think my A3 is 5x100
    Going to get them refrub'd and sprayed either Audi White or Black
  38. Mi11ar
    316
    35
    Removed them stickers on the rear and gave it a quick wax
