  1. IanFM
    IanFM Active Member quattro Audi A5 TDi
    452
    81
    Hi guys.
    Sorry to dig this up again but have done a bit of searching and can't seem to get a definitive answer.
    I have managed to get my hands on a mfsw from a 2001 s3 which looks identical to the standard 4 spoke wheel on my 04 a4 apart obviously from the radio buttons (3 down each side of the air bag). Now my car has full dis and cruise so I'm fairly sure I have the correct steering wheel control module. My question is what else am I likely to need to change these over?
    Cheers in advance guys!
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    26,812
    9,786
  3. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    I wouldn't be so sure that you have the correct Steering Module for MFSW, you can easily check this by undoing the 2 T8 screws securing the top cowling to the bottom, lift the top cowling and read the part number. You can do this with the steering wheel still on.
    If you have the correct Steering ECU then you'll also need a new airbag harness and a slipring.
  4. IanFM
    452
    81
    Thanks for the replies so far guys.
    Sandra I had read through that previously and unfortunately its for fitting a b7 steering wheel to a b6 so wasn't sure how much would apply when fitting what I suspect is a b6 steering wheel.
    Jb I read elsewhere on this forum that the highline steering wheel ecu required for cruise and dis also allowed mfsw?!?
  5. archemist
    archemist Active Member VCDS Map User Audi S3 Team Brilliant Black
    247
    31
    ross tech say:
    Cruise Control Retrofitting (8E) - Ross-Tech Wiki
    so according to them highline is only needed for steering wheel heating - hence mid-line, if you have it, may work anyway.
    the parts catalogue only list one slip ring right up to 2005
    [TABLE]
    [TR]
    [TD="bgcolor: #D7DBD3"][TABLE]
    [TR]
    [TD="width: 50, align: center"]10[/TD]
    [TD]8E0953541E[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E1E1E1"][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E1E1E1"]cancelling ring with slip ring and steering sensor / F >> 8E-4-400 000
    [/TD]
    [/TR]
    [/TABLE]
    so that's a bit odd
    will look further into it
    And
