  1. roblane65
    roblane65 Member
    33
    Where will I find the steering wheel control module so I find the part no. Thinking of fitting a MFSW.
  2. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,662
    116
    Hi Rob,
    You need to remove the top cowling, this can be done by removing the 2 T8 screws from the bottom cowling that is securing on the top. Lift up the top cowling and there should be a white label ontop of the Steering ECU which will denote the following:
    You will need a Midline/Highline ECU to support MFSW.
    Do you have Cruise Control? If so then you already have the correct ECU for the retrofit.
  3. roblane65
    roblane65 Member
    33
    left you the part no's I was given on folding miirors thread.
